If Your Automatic Climate Control Is Acting Wonky
quattroa4m
3:24 PM
Nashville, TN, USA
If your ACC is acting wonky, you might want to check your inside temperature.
My inside temperature was 63 degrees on a 81 degree day, after the Grenadier had been in the sun for a couple of hours. The interior was warm, yet the ACC was barely putting out any A/C. Manually overriding the A/C worked as you would expect.
I rebooted the display/computer and the inside temperature came back at a toasty 105 degrees. The ACC kicked the A/C in full blast and the inside temperature started moving down...as it should.
So far, a couple of days later, the inside temperature seems to be working as it should.
