How do I remove the rear view mirror 2023 no land departure camera.
joejet
2:38 AM
Far far away
I want to install the wolfbox mirror/cameras but how do I remove the old one from the windscreen 2023 car 1st gen with no lane departure someone told b}me just turn it anti clockwise 45 degrees is that correct? Is there a grub screw I’m haven’t spotted, really don’t want to break the windscreen. Please advise. (Everything I can find is for the later version)
Thanks
I have removed mine in my 23 car with a chassis number in the 2000's. If I remember correctly it was a quarter turn but it was stiff to start. I can send a photo of the removed mirror so you can see the back if it will help you.
If you want to remove both mirror and arm then yes, you turn the arm anti clockwise but you will probably need to use a pair of grips and protect the finish on the arm with a cloth or something similar.
Thanks for the confirmation, I have the wolfbox arm and adapter so hopefully it goes well.
That would be great just to confirm everything
Hi @joejet
Just checking that you know the Wolfbox arm supplied with their mount kit is not suitable for the MY23 Grenadier? It's a generic D-tab (slide on) arm, whereas the Grenadier uses a twist lock stud.
If you haven't already planned for this I would sort out a suitable replacement arm before you remove the arm from your windscreen. It's not a hard job but not one you want to repeat unnecessarily.
More info in my post here, including a suitable arm that will adapt the Wolfbox backing plate to the Grenadier windscreen stud.
Post in thread 'WolfBox - As A New Vendor, Offering 20% Off Discount!' https://www.theineosforum.com/threa...ring-20-off-discount.12416448/post-1333278858
Hi @joejet
I have bought some mount convertera
Hopefully they work
Are you sure, even for the 2023 1st gen model without the lane departure camera?
What stops it working?
I tried a similar kit before identifying and buying the Aliexpress arm. The adapter dimensions were not right and they were too flimsy to support the weight of the Wolfbox screen which is much heavier than a standard mirror.
The supplied Wolfbox arm doesn't place the mirrow low enough to clear the airbag panel or be able to plug the wires in. I spent a lot of time finding a drop arm to move the mirror lower.
Thanks everyone, I have ordered the alliexprees one but as in I’m in the Cayman Islands I have to send via America (or pay $76 shipping + 22% duty on item and shipping) so probably see it in a month - 6 weeks.
A fabulous place to live (I guess) so I reckon you can put up with that delay.
It's always warm ( bit to hot in the summer if you need to work on ineos outside 🤣🤣)
No Tax is the best part, but everything is expensive and you have to wait to gat it.
Also a bit flat, ineos is a bit OTT but gland I bought it over form the UK, as it only did 5500 miles in 2.5 years!
Hi, thank you for the precious insight.
Has anyone got this info? What would be the ball diameter on the original Ineos bracket, once the original mirror is removed?
thanks
@Clark Kent - would the AliExpress arm also work on a LHD vehicle or not? Do I need anything else to mount the Wolfbox or only the AliExpress item?
I can’t see why it would be any different. The screen is not angled towards you so LHD / RHD doesn’t change anything. You still need the wolfbox mounting kit. The provided wolfbox arm is then swapped out for the AliExpress arm. Read my post here
This was for an MY23 mirror replacement. I have no idea if MY24 or later non-ADAS mirror mounts are different. Look at my pics and compare with your setup.
I just checked the parts catalog while I was looking up something else.
The non-ADAS mirror has not changed since MY23 and there are no LHD/RHD variants.
So just the non-ADAS and ADAS mirrors listed.
Non-ADAS. MY23 >
ADAS MY24 > (with camera cover hidden)
Non-ADAS. MY23 >
Thank you so much for checking! My car is from 2023 and has no ADAS (luckily) - I will try out your setup.
