High Temp Coolant Reservoir crystals
chtucker
5:17 PM
Kirkland
I assume not normal and needs to be replaced? I didn't see anything below the box, but I was over a gallon low on coolant which I think was more related to a factory under fill
If its got evidence of coolant leaking around the plastic tanks then they should be replaced under warranty.
You heating will improve but keep checking levels and topping up as required and it will be 'nearly normal '🤣🤞
This is covered at length elsewhere on the forum. Splitting high pressure coolant reservoirs are a known problem on BMW and other engines using these components sourced from the same supplier. Mine was replaced about 4 weeks ago (@ 17000 km).🤷‍♂️
