High Output Aux Switch Replacement?
Deadman
Quartermaster Owner
1:13 PM
Scottsdale, AZ
Baja Designs did me dirty on their spec sheets (or maybe I just read too fast), but I have four LP4s which I though would pull 5.5A each resulting in a 22A draw- perfect for my EXT5 25A switch. Turns out, each is 6.5A- 26A total.
The factory 10awg wire should be fine based on the length of my run, but I would prefer to simply swap out the rocker switch to a 30A versus running an independent switch or adding a SwitchPro/Garmin setup. I can always use a relay, but not sure why my Ineos advisor tried talking me out of that and unable to articulate clearly why.
Anyone have any suggestions for a similar style rocker that would fit the bill? Or does anyone have more knowledge of the other than obvious differences between the 500A factory switch versus the 25A? I want to keep it on the EXT5 circuit in the current position.
