Hi guys, I found the cable ends in the engine bay and in the footwell.
1) Engine bay:
If you stand in front of the vehicle, the ends are on the right-hand side, directly in front of the brake fluid reservoir. They are difficult to see because they are attached to the wiring harness with tape. I have removed the tape.
2 Footwell
The cable ends are located in the footwell on the outside. To do this, the lower a-pillar trim must be removed. Some experience in handling nipples is helpful.
Here, too, the cables are attached to the cable assembly with tape, which I have removed.
I will put sockets (probably Deutsch plugs) in each case so that I can connect devices if necessary.
I plan to do the same for the boot. Here it will be really fun with the nipples, too.
