The same in the Italian Owner's manual...
It also says that on page 188 of the UK manual as well!!The same in the Italian Owner's manual...
Which begs the question why has a brand new wiring looming have wires sealed with heat shrinks? And where are the elusive outlets. And why no apparent fused circuit for the under bonnet outlet. Without a workshop manual the mystery will remain.It also calls the footwell ones “outlets” in the same manner as the others, which are all finished off - ie with either plugs or sockets.
Please be careful! You might get stuck in this car some days.Remember this thread:
What's this??
Was wondering what the thing with waterproof 150A. ignition protected was for?www.theineosforum.com
Well I had a closer look at it today and guess what it says on the lid:
Yes Red Winches. I have no winch fitted.
It's wired off the 3 way MTA connector (front connector) that has the jump start terminal as it's centre terminal. The jump start terminal is obviously permanently live as is the front input terminal of the "black box" (could it be a solid state solenoid?):
The back output terminal was confirmed not live when tested. The cable appears to disappear under the inner wing and down behind the offside headlight. Try as I might I couldn't definitively chase the cable to a point, but shining a torch above the bumper and under the wing, illuminated that looks like a 10 way connector fitted with blanking plugs:
Well page 189 in the version I originally download is a different page, so that looks to be a newer version.just went onto my Grenadier account to check the latest iteration of the manual that’s if it does get updated and yes the front footwell sockets are mentioned
I just wonder if you are looking high enough up. It says footwell. So to me that does not imply kick panel areas, and should you be looking immediately below where the front panel turns into the footwell. Ahhh I wish I had my Grenadier instead of guessing...Well page 189 in the version I originally download is a different page, so that looks to be a newer version.
I am I correct in thinking the Belstaff (or Fieldmaster versions have footwell lights?) are the outlets in this area?I just wonder if you are looking high enough up. It says footwell. So to me that does not imply kick panel areas, and should you be looking immediately below where the front panel turns into the footwell. Ahhh I wish I had my Grenadier instead of guessing...
So an interesting development on this today. The back output terminal was confirmed not live when tested yesterday, but was live today!View attachment 7811639
Good question ~ I'd try and answer but I don't have a Belstaff edition ~ can anyone hear us waving?I am I correct in thinking the Belstaff (or Fieldmaster versions have footwell lights?) are the outlets in this area?
Good man for trying ~ it's a foolhardy one that starts yanking at bits without understanding the fundamentals.I also tried to remove my roof panel, to see if I could switch the connection of my wrongly wired button EXT2 to INT1 (no answer from Hedin or Ineos concerning my "small" wiring problem). The second part of the panel is "one piece". I guess the other one is also one piece. Therefore a "two piece" roof panel probably. But, after rtemoving the screws I was stuck. Probably there is still a clipping mechanism in the middle of the panel, and I didn't dare to take it off, without knowing what kind of clip it is.
I've had a wee look, albeit not being an auto-elec, but have not seen anything resembling any form of electrical outlet.Good question ~ I'd try and answer but I don't have a Belstaff edition ~ can anyone hear us waving?
I sure understand the fundamentals of electricity and electronics, that's why I dare to try to access it, the problem are the mechanical plastic pieces, there is usually an easy way to unclip them, but sometimes I discover the trick after breaking the plastic. It is a pity indeed that they don't make it a little bit easier: supplementary screws in the middle of the panel would have been OK too.Good man for trying ~ it's a foolhardy one that starts yanking at bits without understanding the fundamentals.
But maybe also more proof that some of the built on purpose is more faux than we would hope it to be.
Yes I have footwell lights ... I didn't look at the outlets though.I am I correct in thinking the Belstaff (or Fieldmaster versions have footwell lights?) are the outlets in this area?
Thanks @Jean Mercier. Now if I was designing a wiring loom and said it had 10A customer fit outlets that where in the footwell, then I'd put them next to the footwell lights.Yes I have footwell lights ... I didn't look at the outlets though.
The 'black box'' looks like an auto resetting 150amp circuit breaker which would likely be the high power outlet I guess.....Remember this thread:
What's this??
I agree.. can't be that hard to explain where all the roof switches end up!We are now dealing with delivered customer vehicles, and neither the dealers or Ineos can provide answers to what should be basic questions regarding the vehicle.
If that doesn't scare the shit out of people I'm not sure what would.
