UK & Ireland Heating system
CRH
5:48 PM
United Kingdom
Will the heating system ever be fixed properly on all vehicles. Mine is a 2023 and the heating system is eratic at best but generally doesn't do what you want when you want. Auto is useless. It has had the bleeding procedure done numerous times but it's still ineffective. Hot air at the back and cool up front on drivers side until on max heat. Turn rear vents off helps, turn side vent off helps. Or air on feat and face. Lower than max heat blows cold on feet. The random combinations are endless
HVAC in general.
Including persistent leaking and condensation issues directly into the footwell. This has been going two years for some, and continues to be an issue (I’ve literally lost count how many times my vehicle’s HVAC has been looked at for various reasons).
According to @Stu_Barnes , you need to like my question to get it asked as I have with yours
I hope so, it’s the only thing I hate about the car. Be interesting if the 2025 models are doing the same thing.
Reactions: CRH
@CRH: Was always wondering if I have a lack of competence to adjust the air condition in the car properly. I am facing the exact same difficulty which leads to the problem that my wife (always freezing) refuses to come along when I wan't to take the Grenadier out.
The complete situation regarding the air condition and vents in the car is rubbish and I can't make up any consistent theory on what causes it.
Have the same issue with constant leaking condensate into the footwell, have read somewhere about lagging some of the AC pipework to stop the condensate, but cant find it again.
Anyone completed this task, and able to shed some light?
It is a dealer fix; make them do it.
Would you please list the steps you took to create "the problem" that causes your wife to stay home when you want to enjoy your Grenadier.
Asking for a friend 😒
Have the dealer bleed your system multiple times, if you try DIY, make sure expansion tanks are topped up (check these now and top up). Try turning the front side vents off and the rear seat vents. Now have a go with it, if necessary turn the aircon off too and just use as an old fashioned heater (if only it were possible).
But go and check the expansion tanks are topped up now and see if it improves.
