There is no final flash.HDC Screen is it the final software flash??
But it might be a rollout version.
Speedo may be GPS linked? Just a guessAnyone know if the tyre size can be programmed in?
Unlikely, here in the UK you can in mountainous areas, rarely and not for long, enter a satellite blind spot and hence lose GPS and therefore speedo.Speedo may be GPS linked? Just a guess
And set it to a proper unit of measure, MILES per hourThere is a setting where you can select left hand drive or right hand drive.
For even more confusion in Europe better ft/minAnd set it to a proper unit of measure, MILES per hour![]()
I don't think this is allowed, at least not as a single source.Speedo may be GPS linked? Just a guess
Knots for me, please.For even more confusion in Europe better ft/min
Why has no manufacturer taken up VarioPilot?Does that move the steering wheel like on a unimog.
Do you prefer air speed or ground speed?Knots for me, please.
Thats a good question, it could quite possibly be on the vehicle itself, but we now won't have to wait long to find out.Isn't the GPS in/on the Gren on your phone?
Also, I'm hoping to install a HUD and I believe they run off the OBD port.
Isn't this just the former - reconfigure within?Positive. You can configure a lot of details & info display WITHIN many electronic instrument panels, but repositioning the whole readout is a no no. In Australia the vehicle had to meet Australian Design Regulations which would fix the panel in a certain location.
Both are possible: HUDs use or the speed of your cell phone (therefore GPS) or - if you have it - the speed of the OBD port indeed (usually through bluetooth connection).Isn't the GPS in/on the Gren on your phone?
Yes HUD's generally have Bluetooth connection to a plug on the OBD2 socketIsn't the GPS in/on the Gren on your phone?
I prefer the speed indication of the GPS of my phone. This is almost 100% correct. The speed indicator of the car itself (through the OBD) has a fault margin of around 5%.But why do they need the phone at all? I understand that it’s needed for navigation, track lists and messages. But all pure driving data should come via OBD, shouldn’t they?
Many ( also the most) of them need a Cable to connect to OBDYes HUD's generally have Bluetooth connection to a plug on the OBD2 socket
