Has anybody priced the new 26 steering box?
I inquired at my dealer and was told it was not possible to retrofit the new steering box in previous model years. This seems dubious, I suspect it can be retrofitted, but as a result they would not even quote me a price.
This is the same old story, remember when they said you couldn't add trailer wiring after the fact.
I am 99% certain you can retrofit the new steering box they just don't have the inventory to support lots of swaps and don't want to give the impression that the old box was in some way defective. Give it some time and the swap will become commonplace assuming you are willing to pay the likely substantial cost.
That's more or less what I was saying. They did exactly that with the trailer wiring fiasco.
Recently fitting the Bilstein steering dampener with the Heasman wheel alignment has transformed the steering on my car - which has the old steering box.
@KristinaM is in the process of fitting this combination on her car. That is a US spec car, whereas mine is AU spec (not that it should matter much).
This combo is probably cheaper than a new steering box. I have been shocked the difference it made. It now:
1. steers like a car
2. returns to centre;
3. steering is lighter.
More observations here, including the two following posts:
How will it perform on a really rocky track?
I found the Toughdog shock gives me the flexibility I am happy with, not that the stock setup really bothered me. As an old Landy owner, anything 21st century is space age 😉
I do not know. I have only done limited offroad driving. OK on light corrugations, but I have not done badly corrugated roads or rocky tracks.
There is a little moer feedback and movement on corrugations, verse OEM dampener.
Slowly working though the various scenarios, last one being towing on road.
Last Saturday I drove back home 2hrs in the dark towing 2.5T , and on the twisty, narrow hilly road it felt more reassured than it would have given a loose easy car like setup.
Too car like and you'd forget you are driving a small articulated truck requiring full attention.
I guess we all have our preferenced often terrain/ location related.
In time, some of the MY26 guys might even backdate to the 23MY steering boxes!
The 2026 box has a higher ratio so less turn of the wheel is needed to move the wheels than the previous box.
If that's true then the dead band will feel smaller. That could be a decent upgrade. But if that's the solution then there is virtually no way Ineos will be helping earlier trucks. Assuming the box can be swapped then we will be on our own to upgrade.
I have been playing with the idea of changing my pitman arms length. That could reduce the dead band a bit and make life a bit better. Cost would be minimal.
Could anyone list the drawbacks of this updated steering box? I thought that the reason for the earlier design was that it was sturdier and more effective in off-road conditions, which made it less comfortable as a daily driver. Put a different way, won't the updated steering box sacrifice some of the off-road performance of the original?
Recirc ball steering boxes advantage is more or less longevity due to low wear. They are a bit more durable than alternate box designs but that's somewhat moot.
There really is not a ton of advantage Offroad. They do tend to reduce steering wheel feedback which can be good or bad offroad depending on how you feel about it and vehicle use. But many very competitive offroad vehicles use worm and sector or worm and roller steering boxes with little issue.
My assumption based on preliminary info is that the new 26 box is still recirc ball but maybe a different ratio. So you shouldn't lose any potential advantages.
I was told by XHQ when I installed the slightly heavy duty Eibach Springs to max out the caster 2 degree plus if possible.
The steering went from boat back to truck and is brilliant. The springs are the same height as standard but less sag which also tightens up the handling. Watch the video but I had mine done by the pros(y)
The Best Free Upgrade to Your Ineos Grenadier: Adjusting ...
YouTube · Owl
1 Mar 2024
YouTube · Owl
