It looks expensive. Maybe INEOS will do us a solid and sell it for less profit
This is the same old story, remember when they said you couldn't add trailer wiring after the fact.I inquired at my dealer and was told it was not possible to retrofit the new steering box in previous model years. This seems dubious, I suspect it can be retrofitted, but as a result they would not even quote me a price.
I am 99% certain you can retrofit the new steering box they just don't have the inventory to support lots of swaps and don't want to give the impression that the old box was in some way defective. Give it some time and the swap will become commonplace assuming you are willing to pay the likely substantial cost.This is the same old story, remember when they said you couldn't add trailer wiring after the fact.
That's more or less what I was saying. They did exactly that with the trailer wiring fiasco.I am 99% certain you can retrofit the new steering box they just don't have the inventory to support lots of swaps and don't want to give the impression that the old box was in some way defective. Give it some time and the swap will become commonplace assuming you are willing to pay the likely substantial cost.
How will it perform on a really rocky track?Recently fitting the Bilstein steering dampener with the Heasman wheel alignment has transformed the steering on my car - which has the old steering box.
@KristinaM is in the process of fitting this combination on her car. That is a US spec car, whereas mine is AU spec (not that it should matter much).
This combo is probably cheaper than a new steering box. I have been shocked the difference it made. It now:
1. steers like a car
2. returns to centre;
3. steering is lighter.
More observations here, including the two following posts:
BILSTEIN B6 SHOCKS
The Bilstein B6's were installed yesterday. Too early for any informed comment. They do weigh less than the OEM shocks removed.
They have been fitted for a trip to The Kimberley later this year. The first trip will towing the van in about 2 weeks.
BILSTEIN DAMPENER
I also had a Bilstein steering dampener installed with a Heasman’s wheel alignment. Heasmans are the Australian Bilstein importer and also do R&D for them. They are also behind Polyair airbags, on my car and van.
Wally now returns to centre nicely. It has a rubber protector over the dampener, so...
I do not know. I have only done limited offroad driving. OK on light corrugations, but I have not done badly corrugated roads or rocky tracks.How will it perform on a really rocky track?
I found the Toughdog shock gives me the flexibility I am happy with, not that the stock setup really bothered me. As an old Landy owner, anything 21st century is space age![]()
The 2026 box has a higher ratio so less turn of the steering wheel is needed to move the wheels than the previous box.Is the new steering box better in someway?
If that's true then the dead band will feel smaller. That could be a decent upgrade. But if that's the solution then there is virtually no way Ineos will be helping earlier trucks. Assuming the box can be swapped then we will be on our own to upgrade.The 2026 box has a higher ratio so less turn of the wheel is needed to move the wheels than the previous box.
Recirc ball steering boxes advantage is more or less longevity due to low wear. They are a bit more durable than alternate box designs but that's somewhat moot.Could anyone list the drawbacks of this updated steering box? I thought that the reason for the earlier design was that it was sturdier and more effective in off-road conditions, which made it less comfortable as a daily driver. Put a different way, won't the updated steering box sacrifice some of the off-road performance of the original?
Your CV joints aren’t going to like that max casterI was told by XHQ when I installed the slightly heavy duty Eibach Springs to max out the caster 2 degree plus if possible.
The steering went from boat back to truck and is brilliant. The springs are the same height as standard but less sag which also tightens up the handling. Watch the video but I had mine done by the pros
The Best Free Upgrade to Your Ineos Grenadier: Adjusting ...
YouTube · Owl
1 Mar 2024
YouTube · Owl
They shouldn't notice such a fine movement.Your CV joints aren’t going to like that max caster
