Grenadier winch bumper uk vs australia
No - Ineos are now saying that the front towing plate is not robust enough to use as a front mounting point for the portable winch. They will be saying from this point forward that the portable winch is only to be used on the rear tow hitch. ( In Oz at least)
* subject to clarification on what towball arrangements are compatible...
And I think you have to buy one of the towing kits to get the "Vertical Towing Interface" into which the portable winch locates.
Wow, that is a stuff up.
All fronts are the same on the 90s (REB500200 driver and REB500220) and there is a 150kg difference in the models. Rear springs are different. Surprisingly the 110HD front springs are the same as the 90 rears. The 110 uses all the same fronts as well except for the HD but that has a gross weight of 450k more.
Do they offer "before dinner" and "after dinner" versions of these springs?
I thought of something similar "before pissing and after pissing". 🙃
Is this a physical limitation or something to do with Australian Standards? I have always thought rear tow assemblies fitted to utes here in Oz look to be over engineered, maybe Ineos found that what was thought appropriate for a worldwide market does not meet some obscure Australian Standard regarding front winch/tow mounts???
Maybe the front tow hook isn't rated to 3,500kg
Notwithstanding it would be a possible to use it on the front attached to a recovery point, a bridle off the recovery points, or a double line pull using both. The biggest limitation out of the box may be the length of power cable to plug in.
Perhaps not ideal to some, but if you are actually stuck...
This is correct.
We have only tested the portable winch on the rear. We were only recently asked to look at using it on the front and it is a definite no, the front reciver is definitely not robust enough to use the portable winch.
This is correct.
But strong enough to tow and self recover??????
I presume that there will be a weight limit for towing or manoeuvring using the front tow hitch that is below the 3500kg limit of the portable winch. And I guess for self recovery the two recovery points under the bumper will be a stronger option than the front towing interface
Yes, it's to do with the way the portable winch extends forwards increasing the leverage on the mount.
So you towed the 3500 KG in there and can't use the front hitch to move it out again .
Does the welder have to come out or is it mounted onto the fairlead bolts?
I guess towing 3,500 kg behind a vehicle doing 100kmh might be a little different to pushing/maneuvering a 3,500kg load at 5 kmh in front.
Less dynamic stress.
Rear tow bar & hitch assemblies look something like the picture below (I am sure you know this but others may not) and this would be difficult to duplicate in the front
This MAY be the reason the winch can't hang out the front
For me there might be a big clue in this:
So an Ineos /Magna engineer was asked to design a front towing point and either was given or decided the design envelope around low speed manoeuvreing/final positioning of a 3,500kg trailer. That's not going to be much force/loading, even on sloped uneven ground.
How many of us have just drilled and bolted a towball to a thin steel bumper (maybe using a load spreading plate at the rear), with not even a fag packet load calculation?
Now someone else wants to look at using the portable winch and it exceeds the current design limits. So maybe they'll look to a redesign to allow the winch to operate from the front. It might just be a different design and not add more weight, or it may add a significant amount of additional weight and prove to be unfeasible.
Maybe there will be two versions in the future. Who wants to carry extra weight if you know you will never winch from there?
maybe it is an security issue as well. The crash zone might depend on a structure which is not to strong, so that in case of an accident the energy can still be absorbed in the right way.
But I do not know how the steel bumper behaves in this context anyway.
