- Local time
- 1:24 AM
- Joined
- Jul 27, 2022
- Messages
- 6,005
I think you can still rig with a snatchblock, especially if you already have one and don't want to go to the expense of a 2nd snatch ring.G
good point. This means we need two rings. One for the end of the winch line and another instead of a snatch block to be used as a snatch ring when using a double line pull
In either case, though, you will need 1 or 2 soft shackles, as the rings carry a warning: "Warning: This product is not to be used with steel D-Shackles or Bow Shackles. Only Soft Shackles should be used"
