Grenadier plug and play Soundsystem How we do it
SiMsound
Supporting Vendor
6:04 AM
Wunstorf, Germany
Plug and play sound system extension part1.
At first I´m not an english native speaker. I can speak english well but because of time I´ve used for the following text Google translate. If there are any missunderstanding please feel free to message me.
Some of you already have it or know that we have had such a system since the middle of the year. It's an open secret that the Grenadier has a very poor factory sound system. I would be inclined to say that you can't call it that at all. For me that includes the premium sound system. In this thread I want to tell you more about the existing system, why it is so bad and the technical structure.
Afterwards, of course, how we tackle the problems with our new systems in order to create a real sound system that also deserves the name.
First of all, the technical differences beteen both systems.
Standard system components:
- Front doors: 6inch 2-way coxial speakers
- Rear doors: 2-way 4inch coaxial speakers
frontdoors
reardoors
- 4 channel radio unit below the steering wheel
All speakers come from the LaVoce factory in China, which is owned by Elettromedia. For your information, Elettromedia is a very large, well-known italian manufacturer that is extremely well known for the aftermarket brands Hertz and Audison (small spoiler. We will also be using Elettromedia speakers from Audison in the new system). One of Elettromedia's most famous projects is the Sphere in Las Vegas. Their internal speaker equipment also comes from them and shows very impressively what you can do with audio technology. Elettromedia was founded in 1987 and has been active in the automotive audio sector for almost 40 years.
In clear words. Elettromedia is a highly professional company! The problem is once again elsewhere. At this point that would definitely be Ineos. On the one hand, it was decided to only use coaxial loudspeakers. What does it mean that, due to the tweeter being positioned very low at the front, no stage performance can actually take place? In addition, the tweeter mounted on the chassis wastes valuable membrane area on the woofer, which results in significantly less bass than a classic two-way system with a separate tweeter would have. The rear speaker is unnecessarily small. Both the door construction and the exit surface of the door panel grille would have allowed for at least a 5inch speaker. The rear speaker actually doesn't make any sound below 100Hz, which means that it doesn't contribute anything to the bass. The cause of all these decisions will certainly have been a cost decision. They took the cheapest possible LaVoce automitive loudspeaker that was conceivable. Just as a small calculation example. A Hertz DCX100, which is very close to the rear speaker used in the Grenadier, costs me, as a good Elettromedia customer, around 10.50 dollars each. However, the included accessories in the packaging and the sales packaging itself are also included here. Speculatively, I would say the net price from Ineos for this speaker is around 5.50 dollars per piece based on the order quantity. the front speaker around 9.50 dollar. In other words, all speakers together probably cost around 30 dollar. Nobody should be surprised that it doesn't work.
The same applies to the radio unit. This is generally very linear, which is good. But the performance output is very poor. At a 4 ohm load (like the original speakers have), the radio produces a sensational 5.52 watts per channel at the front and 5.76 watts per channel at the rear. Which is a total output of 22.56 watts.
frontchannels pwoer measurement
rearchannels power measurement
frequency measeurement
That's a kind of a joke! Every 80 dollar radio has about twice as much power. The fact that it still works at all is due to the abnormal efficiency of the factory speakers. But miserable enjoyment cannot arise like this. This can be seen in the acoustic measurement of the Grenadier with the microphone positioned on the driver's seat. The turquoise line would represent the reference of how the measurement would ideally be. The yellow line is the Grenadier. Here you can clearly see that there is a beautiful dent in the bass range between 50Hz-100Hz. The elevation in general would not be a problem. This is even desired by most customers. But the dent makes it very inharmonious. Espacially the relative difference between 120Hz (highest point) and 420hz (lowest point), the difference minus the desired 8db is approx. 22db! This corresponds to a volume reduction of 730% to less than two octaves. that's really bad. Up into the treble range, it's more of a rollercoaster than a waterfall diagram. From around 2.5kHz you could still let it go. But that's not cool either.
acoustic mic measurement
Premium sound system components:
- Rear doors: 2-way 4inchcoaxial speakers
- Radio unit under the steering wheel
- Active subwoofer under the rear seat on the passenger side
To make one thing very clear in advance. The system does not have an amplifier that supplies all speakers with more power! The amplifier is located in the housing of the subwoofer and only drives it. Otherwise the system is completely identical to the standard system. The active woofer used is a JBL Bass pro Nano which has a 6x8 inch driver. The internal amplifier produced an output of almost 100 watts RMS. I have no idea how the partially communicated values of over 700 watts come about with the premium sound system. Ineos does not provide any specific information in the configurator. However, the statement regarding the amplifier is very misleading in the configurator. Original sound in the configurator: “Upgrade the standard sound system with a subwoofer and a more powerful amplifier.” Of course, this can be misunderstood. You can easily buy the subwoofer online for around 180 euros. Even if we sold it including cables and assembly, it would be around 680 euros. With 720 euros, Ineos has a very lucrative margin here.
In short words, the system sounds exactly like the standard system only with a little more bass. But the bottom line is that it is even worse because money was actively paid. My recommendation is clear. Hands off! Not worth it.
So I hope that wasn't too much theory for you and I hope it gave some people some information. In part 2, which will come in the next few days, we will deal with the insulation and the new system.
Thanks a lot for the introduction!
I am not so much an audio guy and the Grenadiers system normally is okay for me. But nevertheless I am curious about the way you plan to upgrade the different parts of the system to get in total a real premium sound system.(to be honest I have googled your project already. Alone the fact that you began with a queens red car shows that you’re have the right way of doing the job with style 😀
As you are a professional the fact that you like to sell the upgraded system hopefully will not make you make the original system worse than it already is…
No worries. In the past we also cancelled projects as we thoght the OEM system is really good. Or let´s say good enough for 99% of the owners. The last 1% can still make an individual upgrade.
But the Grenadier system is really bad. ;-) The most owners statements confirn our own opinion.
Hallo, kann man bei dir vor Ort mal dem Unterschied "erhören?"
Mit Vorlauf ja wenn du deinen mitbringst. ;-) Das Fahrzeug was hier steht ist ja umgerüstet da kannst logischerweise nur das Endergebnis hören. ;-) Im deutschen Forum habe ich übrigend den gleichen Beitrag auf deutsch. Wenn schreib doch bitte da oder hier in englisch.
I reached the same conclusions. Its why i am changing my speakers to rear coax and front woofers with tweeters mounted in the A pillars. And a proper subwoofer in the trunk. All powered by DSP enabled amplifiers with active cross overs. Also will do a decent amount of noise/vibration treatments of the doors, floor and trunk.
Time for part two. Please note. The main text is translated by Google because of less time which I have. ;-) If you have any further questions feel free to contact me.
So after a much longer period of rest, I found time today to write a part on the topic of plug and play sound systems.
For reasons of clarity, I will only discuss our top system, the V4 Masterpack, since all smaller versions are more or less technically presented in this way.
In terms of hardware, a really good sound system is essentially made up of three things.
1. Good speakers
2. Performance or a high-quality amplifier
3. A subwoofer
Let's start with the speakers. It was very important to us to use speakers with good efficiency. The V1 and V2 versions in particular, which are intended for operation on the radio, are heavily dependent on this because, as you can see in the first article, there is not exactly a lot of power available. But the V3 and V4 Masterpack versions also benefit here. If the speaker is efficient, a compact amplifier can be used, which makes it smaller and therefore easier to install. In addition, it is important that the play is as linear as possible, especially with the tweeter. Since this transmits a good 70% of the sound component, linearity and therefore the need for little correction is important in order to achieve a nice, relaxed tonal result. We only use Audison brand chassis because we get exactly all of that and a highly reliable product that virtually never breaks.
Ineos Grenadier V1 system:
Ineos Grenadier V2 system:
As you can see in the pictures, we designed adapter rings for the woofers. You cannot mount a classic Euronorm basket in the front of the Grenadier because the recess is not made for a 6.5" speaker but for a 6" US speaker. There is an adapter so that the basket sits cleanly and without twisting and you don't have to cut the Grenny. This works perfectly. The V1, V2 and V3 systems use a 2 ohm high-efficiency chassis with extremely good efficiency. With the V4 Masterpack we work with other woofers at the front and also other tweeters that are not as efficient, but are more powerful and significantly more dynamic. There is enough power in the form of the amplifier.
Woofer V1, V2, V3 system:
Woofer V4 Masterpack system:
One should not underestimate the importance of the topic of door insulation. Measurements have shown that the difference between a non-insulated door and an insulated door can be up to four decibels difference at some frequencies. If you now consider that 3db plus an electrical doubling of the signal, it becomes clear how massive the differences in sound pressure are with and without insulation. The significantly more dynamic game and less background noise due to rattling driving noises etc. are also added, but cannot be measured. So I can only advise everyone. Insulate the doors!
Door without insulation
Door with insulation:
With the Grenadier we basically insulate all three levels. Outer door panel, subframe, door panel. Different materials are used here. On the outer sheet there is classic aluminum butyl as insulation and, if desired, a layer of thermal insulation which has a dampening property and, as the name suggests, thermally insulates the vehicle. The subframe is treated with a little aluminum butyl, but mainly with a special dampening foam. Alubutyl cannot be used on a large scale due to its construction. The door panel is processed with a compound material which consists of a layer of aluminum butyl with sprayed neoprene. Here we combine good insulation and damping properties in a material that is ideal for door panels to provide these.
So that's it for now. In the next part we will take a closer look at the topic of amplifiers and subwoofers.
frontdoors
reardoors
Can you please send me the manual and order link?
I have been following your threads and website for nearly two years. If not for BREXIT and the extra taxes I would likely have purchased by now.
Personally I find the factory sound system acceptable but, if it can sound substantially better I am sure I would notice the difference. 😊
The last time I had a sound system that sounded as “good” as the Grenadier was my 1970 VW beetle with 2 speakers in the door. I was planning to live with it but if you have a way to make it better that does not involve sacrificing the limited storage space I would be interested in seeing the rest of your project.
Finally got my V4M install done. All I can say is "WOW!" What a fantastic improvement. Some parts of the install were either harder or more tedious than I'd expected. Locating and removing the connectors from the factory radio was an exercise in frustration. Finally just removed another panel and pulled out the radio as far as it would come out to get a little better view and grip on those damned ornery plugs. Putting your head on the floor board and trying to see the correct plugs was not possible. Let alone getting a good enough grip with leverage. And insulating the doors took longer than I'd hoped for. Both "issues" were mostly due to my inexperience. If I'd been able to find a reputable shop willing to do the job for $800, instead of $2K'ish, I'd have opted for that. But I have free time and saving $2K was worth the experience. The end result makes me very satisfied.
I want to say thank you to @SiMsound for his V2 kit. I finally got around to starting the interior upgrades and first on list was the sound system. I printed the instructions and read them 3 times. I then said, I am over my head and it will take me a day for each door to install the sound deadening and insulation. I found shop who did it in one day for 1300. I gave them the printed instructions which were a added bonus for the guys.
Like others said, wow what an upgrade. My only regret is I didn't go all in and buy V4. To everyone, just do it. I sat in car and I said, this is amazing but I am missing the low end bass. I need to figure that out.
Two side notes. The installer paid @SiMsound major complements for the system but also the sound deadening/insulation. He mention how he never had lines to follow on the material and great directions on cutting. Made job easier and cleaner. Plus more material than needed creating a solid quiet door.
Second note, spoke to another installer of high end systems in high end cars to get a quote. He first said "I'm sorry, but I can't install a kit you didn't buy from me. Where did you get it?'". He thought I order something off Amazon. I replied from Germany and bought it before there was even a car here in America. He then said " oh, do you even know what make it is?". Yea Audison and reason I called you first was because you are a Audison dealer. "Really Audison?!. Well I could do it but it would be several weeks before I can get to it.". I replied, I'm good. I'll find someone else.
1300 for one days work! Seems the US is very much more expensive than UK.
Thanks for all the compliments. It´s always a pleasure to make a customer happy. Btw. 1300 bucks is a lot! We take for the install of a V2 incl. door insulation 600,- Euro (around 530 Dollar).
If you like you can go for the Amp / Sub upgrade which make V3 system out of your existing V2. Write me an Email when you are interested in.
