Roof & Camping Front runner roof rack- wind issues and solution
Levi
Quartermaster Owner
11:27 PM
Mollymook NSW Australia
Hi all, just a quick share FYI.
I had a full roof, front runner slim line II fitted. It’s a high standing rack which I wanted to clear the head board of the Norweld tray.
Whilst I didn’t like the cross bar arrangement that much, I figured it would be well tested and it came with a small under bar wind deflector.
Long story short- immediately I noticed harsh heavy vibrations starting in roof and flowing through entire vehicle. Mounting a go-pro of the roof confirmed the issue with a lot of deflection on all cross bars.
A bit of back and forth with front runner AU (requiring the above video evidence) and they have supplied FOC a truss support that runs lengthways effectively bracing each cross bar. Photo shows test fit above bars, but it needs to be moved below longterm else it affects rack capacity/configuration. A pain to fit once rack is on car.
Now, the brace stops 95% of the issues, its only masking the poor wind flow issues and some wind noise and no doubt efficiency losses are present still.
There is a wind deflector fairing made by front runner which I would love to fit, but I have been informed none of the models fit the Gren. I am going to take some measurements myself to consider options….
So, in short. The high front runner rack with cross bars configuration is prone to wind flow issues, and at a minimum needs the additional brace which is not supplied or advertised (was supplied FOC after the follow up). However, I think it should have a deflector fairing made for optimal use.
Hope this helps others!
Levi
You have to have the wind deflector. We had an FJ Cruiser with a Front Runner rack and I didn't put the deflector on initially. We went on a 2000 km road trip and the noise was insane, a bit like a Boeing on take off. I used a whole roll of duct tape and taped up all the openings but made no difference. Put the wind deflectors on after the trip and quite as a mouse.
The rack is supposed to have the wind deflector
The Front Runner rack is also about 100mm wider than some of the other racks so this could contribute to the deflection of the roof bars.
I put the wind deflector on my 3/4 rack and it made no difference.
But maybe a full rack would be different.
Which deflector? You mean the small one supplied?
I’ve got that on, but want to add the full fairing -
did you find one of these full fairing ones, or just the small One supplied with kit?
This is what I want, but they don’t make one for the gren/rack combo apparently.
I’ve got that small deflector that comes with kit, but per my other post I want the fairing ideally that goes to roof top.
In general, a rack with length ways slats would be better…..
Just tried the small one with the kit.
I want to be able to properly clean the roof and not have leaves and grime trapped around a fairing.
Another pro of the Hannibal rack, off the roof enough to allow cleaning of it properly. Makes it easier for tieing points too and has the track extrusion for eyelets. I'm no salesman but anyone else considering a rack check them out. Peter is also very great to deal with.
