Anyone on the east coast have a stock front shaft we can borrow and return untouched? PM me if you have one handy. I'm having trouble getting time to remove mine for mock up.
I have mine front shaft free to borrow, But I'm in California.Anyone on the east coast have a stock front shaft we can borrow and return untouched? PM me if you have one handy. I'm having trouble getting time to remove mine for mock up.
Not sure shipping works out for that. But let's keep that option on the table.I have mine front shaft free to borrow, But I'm in California.
Thanks @Tom109. Good pics.Here are my stock breathers. I replaced them with raised breathers almost 2yrs ago.
The silver cap is spongy like there is a spring holding it up. It is crimped in 3-4 places retaining it on the breather body.
Inside the bottom of the breather you see what looks like a valve stem complete with a rubber seal. The stem doesn’t move when you bounce the silver cap, but you can push it open with a pick by pushing outward toward the cap. It springs back closed, but with very little resistance. Below are a few photos to give you the best a views possible.
I cannot see any way to remove rubber and fix the breather.
No markings on the cap. I’ll take a closer look at the body tonight.Thanks @Tom109. Good pics.
That accords with the section schematic I posted. The spring sits between the cap and the valve which acts as a piston. The spring is calibrated to 0.5bar. The cap crimps would need to be removed to take off the cap and valve to get to the seal. Not a difficult job.
Is there a brand or markings visible on the cap?
There is not enough "bind" to damage bearings. It's just barely enough pressure to pinch the boot.The Grenadier is my first full-time 4WD (never owned an 80 Series or any Land Rover) so it's all new to me and I find the mechanics interesting - or at least novel. That said I would feel more comfortable with a part time kit if it eliminated the front prop shaft vulnerability - but why would it? Wouldn't there will still be the same front DS issues once the vehicle sees any track requiring articulation?
The part-time systems I'm familiar with generally employ much larger rear differentials than front because of the additional capacity needed and increased wear seen in on-road usage. In the second post you linked "Jay" mentions a problem with the rear axle that prevents a substantial GVM upgrade. Wouldn't that be more pronounced in a part-time system where the rear end would be taking most of the vehicle's load until center-locked? Wouldn't a part-time kit also require a larger rear axle set-up in addition to a the redesigned front shaft?
At 7500 US miles in we've got the tiniest bit of front pinion seal seepage. It's not enough to even drip. This makes no sense to me though. I have other vehicles with over 175K and over 200K miles respectively that are still dry as a bone. All the front pinion seal issues folks are having point to increased bearing wear as binding front CV joints strain the flanges. I'm guessing that the front transfer box output shaft and bearing are larger than the front differential pinion shaft and bearing so the deflection/wear/whatever is more frequent there?
Good questions.The Grenadier is my first full-time 4WD (never owned an 80 Series or any Land Rover) so it's all new to me and I find the mechanics interesting - or at least novel. That said I would feel more comfortable with a part time kit if it eliminated the front prop shaft vulnerability - but why would it? Wouldn't there will still be the same front DS issues once the vehicle sees any track requiring articulation?
I stand corrected!No markings on the cap. I’ll take a closer look at the body tonight.
I hope it’s just a sensorI imagine linked to my failed front shaft but had a red "Stop GEARBOX ERROR" happen to me today. I have been driving around in centre locked since the thing fell off. There is a complete loss of drive and the usual lit D in green on the gearstick pulses dimly.
I seem to recall this happened when the shaft sheared off at the TC.
It happened shortly after I had to give it some welly to get out off some clay today. I turned it off, locked it and then unlocked and it was back to normal - well still minus a front shaft.
I imagine there is some sensor somewhere thinking something is out of whack and throwing a fault???
A large difference in front wheel speed to rear when the logic tells the computer the CDL is locked and it expects to see similar front to rear speeds.I imagine linked to my failed front shaft but had a red "Stop GEARBOX ERROR" happen to me today. I have been driving around in centre locked since the thing fell off. There is a complete loss of drive and the usual lit D in green on the gearstick pulses dimly.
That makes sense. Thank you. Will advise any updates.A large difference in front wheel speed to rear when the logic tells the computer the CDL is locked and it expects to see similar front to rear speeds.
Good questions.
Jay was looking at all possible options then working through the list.
Did the “list” include straps for limiting front axle travel?
They are not. The factory shocks are about 1" too long to fully protect the front shaft. If they were shorter we would not be here. But we would be having a different discussion for sure.Response to @Ovrland Bill:
Jay didn't mention limiting straps but did say the factory shock length is protecting the driveshaft CV.
“… the factory shock length is protecting the driveshaft CV.”
Would that include protecting the rubber seal from acute angle pinching and/or premature wear, or does this refer to a different aspect of “CV Health”?
As an aside, a particular combination of Old Man Emu springs and shocks on the rear axle of my 1997 Defender 90 resulted in an unintended “shock-stop” for the axle. This, in turn, caused the body of the shock, on two occasions, to completely ‘disassemble’ itself!
