Front Drive Shaft Update
That's for axle shafts not Drive shafts. Axle shafts rotate at far fewer rpm's than a drive shaft depending on gear ratio in the diff. In the Grenadier the driveshaft spins 4x as fast as the axle shafts. Those are also being used for racing applications that get rebuilt for each race.
An accordion style would have to be more like hard plastic such as the one on the Grenadier for the slip joint. But these won't work at angle, the plastic will fail quickly.
Yes that is an axle shaft in the video but similar arrangements are used for driveshafts. Take a look at this factory front driveshaft for a Jeep Liberty. Something like this with a soft "CV Saver" installed inside the accordion boot should work. The larger aperture opening will give the CV Safer and boot room to flex.
I think we can agree that part of the problem is the small aperture paired with the small boot diameter is causing the issue. It really generates a hot spot because it requires a tremendous elongation percentage for the small amount of boot material. We need to spread that elongation over a larger area. We also need to keep the grease in the joint. I believe this arrangement will accomplish both goals.
Is this a perfect solution... no. The perfect solution would be to fix the pinion angle but that is much more involved. Maybe someday a company will offer cut and turn axles on a core basis. They send you a reworked axle and you send them your factory axles after it has been swapped out.
View: https://www.youtube.com/watch?v=Wi1nx53M4dY
Just trying to read the tea leaves here so a CV for a Porsche 93(x) with a CV-Saver or Double (inner/outer) accordion boot arrangement with a adapter plate to go from 6 bolt CV to 8 bolt flange on the Grenadier?
Something along those lines. The inner boot will need to be something like the CV Safer so that the grease will stay in the CV joint.
That large floppy boot can't be on the T-Case side. Even with a CV saver all the grease will migrate into the big floppy boot. It will then harden on one side of the boot when it cools. It will then cause a major imbalance and destroy the boot. That issue aside the CV will already be dry at that point and will fail.
You might get away with a much much smaller version of that big floppy boot but not likely. But you are right, the aperture of the stock boot is just too small. A simple replica of the stock part with a larger aperture would solve the problem. But that's limited by the bolt pattern of the CV to a large degree. It could be worked around for sure, but it hasn't been to date even with all the Jeeps out there.
In the meantime, can a failed front driveshaft be removed ‘in the field’, so that rear drive only can be used to take the trail to the nearest flatbed loading point?
We might disagree on some of the details but I think this is the best path forward at the moment.
Ours is being driven around with out the front drive shaft for weeks. Thankfully the tcase design is fantastic, most would not like that. Oil would pour out, or the Rock Track case will do it, but sounds and drives like a car wreck.
Seriously, in 4 H lock you cannot even tell the drive shaft is missing. Remember, the reason 4h Lock would bind on road is no differential speed from to back, but with the drive shaft out its no an issue. Frankly, I have had other shaft issues in the past, and this ability is very handy.
