Front Drive Shaft Repair Day
Well mine just went at 56000kms, nice little split, have been checking once a month or so, as it was just in for a 60000 km service 300kms ago I can only assume its just failed. (Maths not wrong have had earlier service intervals)
I won’t be removing my lift or tyres, for me it works well, soft beach work and long desert travel, not a bad run I reckon, off to chat to the dealer, if no warranty I have already ordered the joint. If they do warrant I will try and keep old for a spare.
I have one suggestion for people installing the Terra Joint.
Do not tighten the stainless clamp or what have you to the point that it hold the boot in place on the shaft. And do not stretch the boot to the paint line left by the old boot. Let the collar of the boot be just loose so it can settle where it wants. It's already a tight fit so grease will not come out. I have a suspicion this is partially causing premature failures and could explain why some get 4k miles from a joint and others get much much more.
I’ve wondered the exact same thing even for the OEM joint. Maybe the vendor assembling them for Ineos has in some batches clamped the boot collar a little too far down the shaft putting a sort of pre-tension on the boot and when installed fails sooner in some instances?
At this rate replacing the CV joint must be considered scheduled maintenance at 10K intervals. Check the boot regularly and if it fails replace it, but once you hit 10K failure is likely so just replace it proactively. At least it is a simple job that can be done without a big time commitment for modest cost.
I feel I'm going to implement this policy. 2nd failure now (diff end this time) at 30k kms. Much easier to regularly replace in the workshop than on the side of the road.
It’s a shame that the whole joint has to be replaced for the sake of a rubber boot that must only cost a couple of quid. A replaceable boot would be a good idea.
The New joints would allow that. Someone just needs to contact the manufacturer and buy enough stock for it to make sense.
I think one of the norcal guys is at 40,000 miles on his stock joint and 2.5" lift.
Yep, there is some voodoo going on with some trucks. Though not advisable, dialing out some caster will certainly spare the joint a fair amount.
Just kills me every time thinking about how badly Ineos messed this up.
Just kills me every time thinking about how badly Ineos messed this up.View attachment 7907272
EXHIBIT "A"
Ok so here is my current situation - Delivery 12-31-23. Lift and 35s were installed with less than 500 miles on the truck. Now have 25,600ish miles. Heard crunching, saw torn boot at transfer case, bought new joints and tools.
I started disassembly yesterday. All bolts out front and rear.
CV is stuck in/at the transfer case.
Heat, PB Blaster, slide hammer, bad words and now two ratchet straps from front axle to driveshaft end and it will not budge.
Any tips or any thing I am missing?
I would bolt it all back up and take it to the dealer, but I don't have time for the drive, even if it would make it.
Last one I did required some good impact to release it.
You can feed a punch from the back of the truck towards the front to catch the CV. Some really solid hits with a sledge will break the corrosion.
Alternatively you might consider reconnecting the pinion side and using the tires to rotate the drive shaft while the transmission stays in park. In hindsight sight that is the method I will try in the next factory joint that crosses my desk.
You probably only need 4 bolts at the pinion to help break the upper joint free.
I invested heavily in that idea and even offered to fund new tooling. Ultimately they decided the geometry was too difficult for them to make a shaft for the Gren and the market was maybe a bit too small. So they backed out of the project for the foreseeable future.
Thanks for trying.
Thanks for trying.
Thanks for trying.
