- Local time
- 11:56 PM
- Joined
- Apr 16, 2022
- Messages
- 1,061
- Reaction score
- 2,216
- Location
- Yarra Valley, Victoria, Australia
Actually that’s a good point about the oversteer, I had forgotten that until you mentioned it.I was the first in the car this morning. Silver trialmaster. PT02. Short track along the resort of about 100m then straight onto the course through bush tracks. Never faster than about 10-15km/hr unfortunately so didn’t even get to hear the engine rev. I did the whole track in High and only locked the CDL for a short rocky climb to see how it changed things. It would have done it without the CDL in easily. The course certainly didn’t demonstrate the IG’s potential off-road capacity as it was pretty straightforward and not technical at all really. There was a bit of a decline I put it into low on. Low CDL locked foot off the pedals and it wandered down in first never going faster than 6km/hr. Nice. It is a bit prone to over steer and often had to pull it back around the other way after turning too far based on what I am used to. Neil pretty much just allowed me to drive it how I wanted to, taking a harder line if I wanted and he just pointed the way. All the guys were very welcoming and knew their stuff, if not all the technical stuff around batteries etc I wanted to get into. Joel from SLRV on the gold coast seemed like a good guy to deal with, and mentioned that the last thing anyone needs to worry about was the on road drive, nice and tight and eats it up.
For me the interior was a bit more agricultural than I expected in terms of plastic finishes etc, and was certainly more towards the 70 Series cruiser style than the 200. I assume the fit and finish and perhaps some of the plastic fixtures will be better done out of production because some of them felt almost Chinese rather than what you’d expect from the Euros.
It was also a bit smaller than I thought it would be externally and internally. A bit bigger than a prado. Snug without being small. But again I’m coming out of a 200 so most things are small by comparison. So others probably won’t have the same impression.
Rear draws will need to be no longer than 700-750 with the cage in the back, well short of the 1000 in the landcruiser. Good width though and identical to the landcruiser from wheel hump to wheel hump. But the rear load space is HIGH. I reckon you could easily put some sort of rack system in the back on a trip to make full use of the height.
I found it coming around a slow corner under acceleration holding the turn for too long.
Nearly found myself testing out the wading depth in the nearby dam.
