Fluid-Dynamics/Aerodynamics of Front window/mirror ice build-up
MileHigh
That Guy
12:22 PM
Colorado
Last winter especially, but even in the summer with a lot of rain/dirt, the driver side window seems to collect a lot of scuzz and ice on the window, right where I want to look into the mirror. I think the side mirror also picks up build up. I’ve even seen it on car washes with blowers- I need to wipe my window/mirrors down.
Anyone else notice this?
Thoughts on some vortex generators or something to help disrupt this? I can 3D print stuff.
Yep, it's a common problem. The side mirror creates a turbulent wake that directs dirty air and road spray right onto that spot on your window.
Vortex generators are a good idea. A small, carefully placed one on the mirror housing or the A-pillar could help clean up the airflow and keep that area clearer. Worth a try since you can print them.
Rain-X or ceramic coating on mirror and headlights. Until a solution is found.
It is my biggest annoyance with the vehicle. Notice any other cube car has gutters or rubber strips on the A pillar (like G wagon).
My ClimAir wind deflectors seem to make a difference for me. They just break up the airflow around the front of the window.
Just circling back to this as it’s winter time.
Any more thoughts, especially on vortex generators? Size, number and orientation ?
I installed a set of these the other day. I've not yet been able to test them in appropriate weather, but am hopeful.
Did they work?
Same - a lot of road salt this year and not too bad - I think maybe an unintended benefit of the Climair deflectors
It was what I bought them for - my old Defender had something similar and that first winter I had the Grenadier made it clear I needed to do something. It's certainly not for the asthetics, around here they are known as Vape Vents by the "Influencers"
Yeah but you are much smarter than I am . . . except when you’re navigating large bodies of water.
