Error Message "Tyre pressure sensor lost"
2600 miles in mine started this...this morning.
Although not an explanation of why, hopefully they will come back online after you park it for a bit. Just give them a few blocks to reaquire once you start driving again. Has happened to me twice so far.
HF - I had this happen to me. Initially the warning was for low pressure which disappeared after an hour or so driving. However the next day the lost TPMS message appeared. On the off chance I checked the TPMS valve on the offending wheel and it was slightly loose. Once I tightened it the warning disappeared and, touch wood, continues to work perfectly.
Thanks will check all valves
Mine did this once and then had a complete electrical meltdown. That error popped up, then an error stating a rear brake light was malfunctioning, then AEB error and LDW Malfunction. Dash looked like a Christmas tree. All the errors cleared after I powered it off and let it sit for an hour.
Been having lost tyre pressure sensor since Friday afternoon. I went on a trip around 550 miles. Running psi 34 cold 38 warm. I’ll check the stem, someone said it may be a slightly loose stem. We shall see.
All mine went out the same day my A/C decided I should feel what Hell feels like. After shutting down the truck, letting it sit for the prescribed 5 minutes and 30 seconds (no, I didn't actually time it), all went back to normal.
I've only had my 2025 Fieldmaster ONE week, and this Tyre Pressure Monitoring Sensor Lost error appeared during today's drive. I will let it sit overnight and report back. Thanks for the tip!
This happened to me on one wheel after I had new tires installed. I was afraid the the tire shop somehow damaged the sensor. After I got home I locked the car for 10 minutes and started it up again. It still said lost sensor. I decided to drive around the block and the warning light went off after a minute or so. Also, my back right parking sensor acts up in reverse every so often and senses objects that are not there. A reset of the head unit by holding mute until full screen resets and locking car to put it in sleep mode has worked for me to clear theses annoying quirks with this vehicle. Having an OBDII scanner to clear the fuel fill code was also helpful. Only happened to me once in about a year of ownership.
Mine just did this in the AM. Lost all 4 at the same time. When I was finally able to park it, lock it, and let the ECU fully cycle off….it finally came right back. More annoying to look at than anything, I checked the PSI just to be safe and went about my driving….I just had to pretend it was an older vehicle where we did just fine without dumb TPMS sensors.
I wish that such an old issue had been fixed, but today at just under 2K miles, I got the “Tyre Pressure Sensor Lost.”
I have started the engine a few times and driven another 50 miles, but it persists. Hopefully it clears overnight.
A friend who is not a Grenadier-head commented over dinner, “I have heard of those cars. Supposed to be super rugged but garbage software.” That’s the reputation outside of our community. Pretty reasonable IMO.
