Complete drive shaft as I understandbut from inoes do you have to buy the complete driveshaft or can they supply just the CV joint?
Entire driveshaftbut from inoes do you have to buy the complete driveshaft or can they supply just the CV joint?
Sounds like one to ask your local dealer.I’ve had a look through the comments. Am I right in summarising that 1. It is inconclusive as to whether the Eibach lift leads to front driveshaft problems and 2. It will invalidate warranty (info for the implications in the Uk would be useful)?
My front driveshaft was replaced under warranty but only because I’m on stock suspension. The dealer told me that they are denying warranty claim on lifted Grenadiers. Also said that they see a high failure rate of the CV on lifted trucks.I’ve had a look through the comments. Am I right in summarising that 1. It is inconclusive as to whether the Eibach lift leads to front driveshaft problems and 2. It will invalidate warranty (info for the implications in the Uk would be useful)?
As @Cheshire cat said. I would check with your dealer. I seem to remember speaking to an agent who said that making a warranty claim for a failed prop with a lifted Grenadier would be problematic.I’ve had a look through the comments. Am I right in summarising that 1. It is inconclusive as to whether the Eibach lift leads to front driveshaft problems and 2. It will invalidate warranty (info for the implications in the Uk would be useful)?
Tires don't alter driveline angles, however, from dealing with other brands in the past, it is an additional clue to the big picture.The lift thing I get, but tire size doesn't affect the driveline angles, correct?
Bonus points for the very correct usage of the word torsion in that sentence!Larger tyres may also increase torsion values on rotational linkages, I suppose.
I have 255/85r17 tires. When the dealer replaced my driveshaft they said that Ineos asked about the tires but approved the warranty without issue because the suspension was stock. Perhaps they had the dealer look to see if the suspension had signs of being played with which of course it didn’t.The lift thing I get, but tire size doesn't affect the driveline angles, correct?
1.5M miles nothing...Are there alot more front CV's beginning to fail now around different countries. I find it hard after 1.5 million miles of testing something like the CV angles are an issue. How did this get passed or are the CVs that are failing is because of hwy speeds or something else that never got tested in development. Those that are doing lifts, is this so you can fit larger tyres? And is there a direct after-market replacement CV for the grenadier from teraflex?
When they are doing the pre-production vehicles (which are used for long distance testing) those vehicles often have pre-production parts on them from suppliers. In this case, whatever company supplies the CV, may have provided a more robust pre-production CV than what finally made it into production.Are there alot more front CV's beginning to fail now around different countries. I find it hard after 1.5 million miles of testing something like the CV angles are an issue. How did this get passed or are the CVs that are failing is because of hwy speeds or something else that never got tested in development. Those that are doing lifts, is this so you can fit larger tyres? And is there a direct after-market replacement CV for the grenadier from teraflex?
My VIN is 6492. almost 26k with 99.9% of that time lifted on 35's.When they are doing the pre-production vehicles (which are used for long distance testing) those vehicles often have pre-production parts on them from suppliers. In this case, whatever company supplies the CV, may have provided a more robust pre-production CV than what finally made it into production.
I've got more than 20,000 miles with a lift and 315's and not had a problem. A significant portion of the post lift miles have been offroad.
I wonder if there is a correlation between VIN numbers (how old the Grenadier is) and failures? Did Ineos start receiving weaker CV's at some point, or different rubber compounds? My VIN ends in 6737.
