DVA Mechanics - Ineos Grenadier Rooftop Power Adapter – DTP06-2S Male to 2-Way DTP04-2P Splitter
DVA Mechanics
Supporting Vendor
5:42 PM
Atlanta, GA, USA
DTP06-2S Male to DTP-04-2P Female Splitter Cable for Ineos Grenadier – Plug & Play Rooftop Power Adapter
Effortlessly power multiple accessories from your Ineos Grenadier’s factory rooftop DTP port—without cutting, splicing, or modifying your wiring. This splitter cable features a DTP06-2S Male connector that plugs directly into the vehicle’s rooftop power port and splits to (2) DTP-04-2P Female connectors, making it easy to run multiple devices while preserving the OEM wiring.
Whether you’re powering rooftop lights, camp gear, or auxiliary equipment, this adapter enables a clean, professional, and weather-resistant connection that’s ready for rugged overlanding conditions.
Key Features:
✅ Direct Factory Connection – DTP06-2S Male plug fits Ineos Grenadier’s rooftop DTP power outlet
✅ Split Output with DTP-04-2P Female – Connects directly to compatible DTP-equipped accessories or secondary power harnesses
✅ No Wire Cutting or Splicing – Preserve your gear’s original wiring and maintain resale value
✅ Plug & Play Simplicity – Saves time during installation—no tools or crimping required
✅ Outdoor-Ready Build – Weatherproof connectors and rugged materials ensure long-lasting performance in harsh environments
Why It Matters:
If you’re outfitting your Grenadier with off-road lighting, camp gear, or other 12V accessories that use the DTP connector standard, this splitter cable makes integration seamless. No guesswork. No electrical headaches. Just solid, reliable power—right where you need it.
Upgrade your power setup with confidence. Order your DTP06-2S to DTP-04-2P splitter cable today and keep your wiring clean, functional, and trail-ready.
Would this also work inside on int 1 and 2
INT 1 and INT 2 have unterminated ends, so you don't need the DTP spitter (unless you add a DTP plug to the end). If you let us know your application, we can help make a recommendation.
I was going to add a DTP to make things easier in the long run. But my goal would be a splitter that can run USB charger for the front seats and then have a the second one to run for rear. Basically first class and economy set up. I'm still in thinking stage of the interior set up.
Here's another product we just posted as well!
View attachment 7892644View attachment 7892647
What is the wire gauge for this splitter? (It is not listed like the IP65 splitter.)
Great!
@DVA Mechanics Not sure how many people would buy one, but I am highly interested in a Grenadier DTP roof out to Anderson in, to provide power to a Bush Company rtt.
Happy to provide details via pm in case this is something you‘d be interested in manufacturing.
Can you send us a photo of the Anderson connector?
The most commonly Anderson used for 4x4 and caravan purposes is the 50 amp Anderson plug. Very, very common in Australia.
Some of the common pitfalls in using Anderson plugs are discussed here. In short, use a genuine plug not a "Anderson style" plug for the best compatibility.
Because of the different size in wiring between DTP plug and a 50 amp Anderson you will need to choose the right Anderson lug to crimp. You can buy genuine 50 amp Anderson lugs in 3 internal sizes, 6AWG, 8AWG or 10-12AWG. Even the smallest internal size will be a challenge to crimp using wire gauge commonly used in a DTP plug (25 amps max). Soldering maybe be the better choice.
Anderson plugs and lugs do come in other sizes like 125 amp.
Don’t have good pictures, would this be useful for you? Thanks!
We will make a cable and send it to you to test. 3 of the roof ports are 12v/15A and 1 is 12v/25A. Do you know what the draw is from your tent so we can be sure it won't blow the fuse? It will be ~2 weeks before we get it done, but we'll give it a try!
Shoot us an email to info@dvamechanics.com with your address.
wonderfully generous, thank you so much!!!
the draw will be within range I suppose, there are some tiny led lights, usb outlets to charge phones, and a 12v fan. basically saves us from bringing power banks up the stairs each night.
I will send you an email!
Great news, thank you so much!!!
Will report once it arrived.
@DVA Mechanics let me suggest to you which cable would be nice if you could make...
A cable that i can install in between the headlight 6 pin Deutsch connector that pulls out the full beam wire as a trigger for a relay.
I like the idea of adding a female and make plug with that wire pulled out.
Just like what is described in this post
