Diff Locks in High Lock
Why cars have 7 different modes is beyond me.
These are just for the stupid that don't know how to drive at all outside tarmac.
Same with Land Rover. A client once drove to a flat, wet field, not even soft, with his Range Rover Sport and parked it there. When he tried to leave he got stuck and later told me: "None of the programs did help!" :rolleyes:
10 years ago in a car park a woman backed into the rear 1/4 panel of my 1981 Porsche 928.
She got out and said "that's the second time my reversing alarm hasn't worked"
Words failed me.
But I use manual shifting on easy tracks to keep revs reasonable. And for more difficult ones I either downshift in advance or use D.
I drove today trails in El Teide and made some observations. The trails are pretty easy, no hardcore offroading. I did slightly over 50 km in ~3 hours which averages ~15 km/h (10 mph). Some typical sections:
To prevent rain water damaging the trais there are small angled ditches across the trail. There may be one on every ~15 meters (~15 yards) or any uneven distance. One can be seen in the picture above and here is another one, which is reinforced with stones. The depth varies between 25-40 cm (0,8-1,3 feet). As these are usually angled (at around 60 degrees) there is a combined pitch and roll-movement when passing. Grenadier's suspension takes these with ease at 30 km/h (~20 mph). I did some at over 45 km/h (28 mph) but it started to be uncomfortable.
Actual driving speed was typically around 20-30 km/h (12-20 mph), sometimes less and especially on the even part close to Izaña slightly more but usually not over 40 km/h (25 mph). Low ratio on transfer box and manual mode on gearbox were used all the time. Center diff lock was used only once on a steep rise with water induceed ruts. Some observations on my petrol-engined Grenadier:
  • About 60% of the driving was done on 6th gear, 30% on 5th and 5% on both 4th and 7th gears.
  • 6th was perfect for 25-35 km/h (~15-22 mph) with revs around 2000 rpm.
  • 5th for 15-25 km/h (10-15 mph).
  • When using 6th the gearbox controller proposed 5th at ~1500 rpm but did pull on a slight uphill well down to 1200 rpm when it decided to use 5th.
  • When stopped gears went down to 2nd without any intervention. When moving off, all shifts 2->3->4->5 can be made in just a few seconds.
And here's me, my Grenadier, slope of El Teide from altitude of ~1200 m and Gran Canaria slightly behind clouds.
It should be instant termination for damaging a Porsche 928
Luckily I am mature enough not to lay harshness on village idiots. After all, they are mostly victims of consanguinity.
We need to be able to use the diff locks in high range locked center diff.
It's such a hassle, you approach a difficult section when you are in high lock, then you need to
- stop the vehicle
- get it in Neutral
- set the T case to low lock
- push the brake and put back to Drive
- now keep pusing the diff lock rear for 1 sec
- keep pushing the diff lock front for 1 sec
For a vehicle that is about simplification, this is such a hassle, also all the nanny systems in place are terribly annoying. And then you still need be lucky that your t-case shifts smooth to low range, this is known to be an issue, sometimes you need to keep the vehicle rolling a bit to be able to shift to low lock.
Like in old military vehicles like the bombardier iltis, this used to be so simple to get diff locks on, just flick 2 switches, and done, no conditions etc, and extra steps, no nannies.
Locking the diffs in the grenadier should be very simple, just push the diff lock button, and then done. Then you can also keep your momentum on the trails, no need for stopping.
Petition for this software change!
Just watched this video about an unimog and saw the 4x4 system and the pneumatic diff lock system (both rear and front) explained:
View: https://youtu.be/mPAhZJMXAUw?si=GOTRIwqQ99_Is4Eh&t=252
Just wow, how easy is that! Just a flick of a switch, going from normal to 4x4, to diff lock, in under a second.
The grenadier preached simplification, this is how the diff lock system should have worked (with rear and front seperate). If you compare that with the 6 step process of the grenny we are far from that. I have a MY23, so i don't even have the change of mind update, so before i can turn the locks back on, the system has to 'detect' it's off, before i can use them again, what a hassle. Hopefully, the change of mind update will become available for MY23.
There are plenty of times In New England I’m on normal roads I turn off to dirt and a short stint on a class 4, then back. With my Toyota and Gwagon, if I see difficulty ahead I can maintain any momentum, hit the lockers to be prepared or prevent an issue, and ride right thru. Being able to do so without stopping is a tremendous aid in preventing wheel slip and trail damage. I can even shift the 95 gwagon to low while moving if I see fit (which I have practiced but can’t say I’ve needed it).
The nanny controls on the Gren were a pure compromise to warranty and legal, and nothing but a detriment to skilled use and protecting the environment.
Period.
Agreed. I would rather they could be activated in high range and Ineos protect themselves from liability with an old school idiot warning plate on the dash or door or sun visor like the Japanese trucks used to do.
I do this with my Land Rovers, both up and down. Fairly easy with manual gearbox. Also useful when towing heavy trailer when starting uphill. Never dared to try with automatic gearbox.
With an auto you just drop it into neutral while still moving and make the transfer case shift then hit drive again. Makes it pretty smooth actually.
As you said 'used to' and as @Zimm said 'legal', is this the problem. Just a sticker saying 'don't be a dick' doesn't hold nowadays.
It does all seem a bit of a faff that you have to memorise a procedure just to turn them on. When I first got mine I thought they weren't working until I went to the dealer who showed me the correct sequence. I can't see why it can't be simple but you more experienced 4x4 users will probably know what can occur when some idiot buys their first proper 4x4.
Given the number of ignorant numpties who buy computerised cars nowadays, I can see how Ineos felt the need to use the stop and think setup - to prevent a rash of damage claims - something a risky startup company does not want.
You might not like it, but it's not your bank account at risk!
I can live with it , and if I'd couldn't I stay with something designed last century.
If you are on any kind of loose surface, mud, gravel, sand, snow etc you should have already locked the centre anyway. Braking and handling are much improved. It's just much safer.. and you can lock the Grenadier centre on the move no problem, I have done it many times.
So with the rear lockers it's different. One sure way to break driveline components is to generate high wheel speeds with very low traction (say a wheel in the air) and then suddenly find traction. The shock load will often break something... So I don't see a situation personally where I'd want an axle locker in high range.. The Grenadier goes pretty fast in low range anyway having all 8 gears.
The G tcase is fully synchronized.
ahhh... Open diffs will do this if spinning fast and the driven wheel suddenly finds solid traction. I've blown 2 2001 LC100 center sections that way a 2 and a 4 pinion. It just shock loads it. Never had a locked diff rip the gears apart as theres no "differential" in moving parts speed. When toyota put adas in the LC100 in 2000, the front center section was changed from a 2 pinion to a 4 pinion because ABS intervention sending power back and forth would cause the diff to fail. As it so happened the LC scrap yard sneekily sold me a 99 center section as a replacement when I requested a 2001 or later. The adas toasted it on a simple crawl at 1800 rpm.
Lesson being, to prevent damage, traction aids are best activated before losing traction, not after. (in a perfect world)
How are braking and handling improved?
I use center diff on dirt roads, I’m not sure how much different it is than unlocked and ESC active? Where I’m unsure is in slick/snow where I’m at highway speeds and unsure the relative advantages of 4Hi-lock and 4Hi-ESC, not so much traction, as stability- keeping the pointy end forward.
I don’t know if it is possible, but it seems to me that a limited slip differential on the rear would be interesting. That way you will get some motive force on the rears if one of them is pure slipping. The turn radius on the IG is so big, it probably wouldn’t affect driving much.
