We need to be able to use the diff locks in high range locked center diff.
It's such a hassle, you approach a difficult section when you are in high lock, then you need to
- stop the vehicle
- get it in Neutral
- set the T case to low lock
- push the brake and put back to Drive
- now keep pusing the diff lock rear for 1 sec
- keep pushing the diff lock front for 1 sec
For a vehicle that is about simplification, this is such a hassle, also all the nanny systems in place are terribly annoying. And then you still need be lucky that your t-case shifts smooth to low range, this is known to be an issue, sometimes you need to keep the vehicle rolling a bit to be able to shift to low lock.
Like in old military vehicles like the bombardier iltis, this used to be so simple to get diff locks on, just flick 2 switches, and done, no conditions etc, and extra steps, no nannies.
Locking the diffs in the grenadier should be very simple, just push the diff lock button, and then done. Then you can also keep your momentum on the trails, no need for stopping.
Petition for this software change!
