Clunk / Thunk - front suspension
Asnes
7:26 PM
Louisville, CO, USA
So I’ve had my grenadier for 9 months now. I’ve done about 200-300 miles off-road. Here in Florida we have a lot of sand tracks through the national forest that often undulate giving you a bit of a roller coaster ride of up/down motion along the tracks when Sunni g at say 20mph.
When going in a straight line, over these humps and into dips, when the front axle springs compress (uniformly) I get a distinct “clunk” or “thunk” sound. Not metal on metal, and there is no hard bottoming out.
I’m thinking this is perhaps the bump stops engaging as the springs compress? Maybe bottoming out the shocks?
I’m not concerned but has anyone else experienced this?
Just curious. I love exercising the grenny off-road!
Yes I’ve experienced the same on sand tracks earlier in the year. In my case the problem was caused by slightly misaligned steering trackrods rubbing/fouling when the suspension compressed.
Cheers
Steve
Check the steering damper bolt is not hitting the long steering arm (sorry names maybe wrong), if it is you will see the witness marks. I had the same after my dealer corrected the alignment. Was adjusted again to eliminate the noise and it's now perfect.
