Check your NATO plug
A few weeks ago I threw away a piece of thick rubber, moments later going to the trash, thinking of the little moisture problem the Grenny has...
Did cut it to size with a sharp knife, have washed the car 3 times & some rainy days, no more water inside the connector!
Easy fix.
Rule of The Shed.
Don't throw any piece of wire, plastic , rubber , wood or metal away unless it has been in storage for at least 7 years.
If the wife complains , get a bigger shed , or.....
Try to open, impossible, not with force, not with chemicals to remove the corrosion, not with heat…….. Now will open a claim at the dealer.
After @Lollo050968 didn’t manage it, I used my favorite spray this morning. This evening, I sprayed again and, wearing rubber gloves, was able to open the NATO connector by hand. No water it dust inside. Before, without spray, I had no chance and could already see myself using grip pliers.
Lucky you, did not work for me. Dealer will be kind enough to attend to this - if it breaks, immediate replacement would be handy.
Update: Workshop managed to open, apparently without causing structurual damage. Cleaned, lubricated, and fitted with a rubber ring that is resistant to fuels and chemicals across a wide temperature range. Thanks to the rubber ring, no further water ingress detected so far. Remains to be seen how it will perform in winter with salt and moisture.
FFKM or FKM Viton offers best temperature and chemcial resistance, as well as elasticity. The one in my picture, above is the one in TheDocAus‘ Amazon link (Sure Tec FKM).
the more i look at these, the more I think swapping to a single pin nato is the way to go.
I never even look d at the PTO vehicles, but thought the NATO plug was 12-pin like for a Sankey trailer.
On my last outing we were running in very powdery sand. Almost like talcum powder. When I popped the cap on return there was about a 1)2 teaspoon of sand inside the cap. I am going to add a cam lock gasket for water protection and use dry graphite lube for the threads. Any sort of liquid or grease would have trapped that sand in the threads in my opinion.
I've had my Grenadier for a month. This thread motivated me to check the Nato plug. I'm not sure how to remove it. Just twist off? It sure isn't moving easily. Do I first have to somehow remove the bar that sits across the top of it?
