Are the diff drain plug’s magnetic to help trap the fine metallic material in the oil?
Can't speak for the drain plug as not touched it but the fill plug certainly has a strong magnet. Saved me dropping it once. Presume both are the same.Are the diff drain plug’s magnetic to help trap the fine metallic material in the oil?
Are any of the diff plug parts one time use?They have an o ring
After noticing the front seal leaking I've topped up ours 5 times in the last 3 months and never changed or put a new seal in. About 400ml roughly to date, (circa 2200 miles).Are any of the diff plug parts one time use?
