Rear skid plate bending over in terrain
Tjeska
Quartermaster Owner
1:12 PM
Oostende, België
For some time now I have the feeling that the stock rear skid plate on our QM isnt really working how we want it to.
Most of the time it digs itself into the ground, folding over & taking some soil samples with us home.
Biggest problem is that the skid plate is bolted down on the rear bumper mount, so the skid gets folded over & rear bumper hangs fairly crooked.
I can imagine this is a QM only problem, the lengthened chassis overhang is responsible for this.
We encountered this on multiple occasions, even when softroading/greenlaning.
Does anyone know a decent solid aftermarket solution?
I would like to see someone design one that has a sort of supported angled front ramp, helping to get he chassis over the obstacle instead of digging it deeper in & folding over.
For time now I will remove the skidplate, until someone makes a decent replacement.
First off good on you using the quartermaster as a earthmoving machine. I haven't found one that matches your thoughts here, same as mine. But I'll keep on looking too. I have dub my Grenadier as well, specially climbing in and out of rivers.
Hello @Tjeska I had the same issue. Removed the skid plate too, and I’ll probably get one from Rival in the spring.
Do they make a specific QM version, or is it this one that you will get?
Our QM's doesn't seem to have the two mounting points near the rear springs?
So don't know of this model will fit/has decent support if it hits something.
Just an idea. Would it be possible to:
  1. Straighten the original (enought to function)
  2. Add a slide plate to forward edge
  3. Add welded stiffeners inside it (depends on available space)
I thought the same, but it will be much stronger to just make one out of one piece...
Stiffer bracing will be necessary.
Your drawing is exactly what I'm thinking of!
As you mentioned this is a QM problem as the skid plate was designed to protect the muffler in the station wagon. For us it's a big scoop and really provides no benefit. I talked to Thomas of black sheep about making a skid. He was like, no real purpose, just pull it off.
Now, on my new flat tray, I will have a skid that basically goes from rear diff all away and wraps up on to the bumper. Part of it is a underneath spare tire holder. When I get it home, I can measure it for you and send pictures to give you ideas.
Wierd, the angled piece between the chassis rails (where the tow hitch, AUX power and 14 pin trailer plug mounts to) will scrape then.
A skid plate is needed to protect this & guide it over obstacles.
I have had contact with Dieter from D&G tuning.
They have designed a rear skid plate with supports for the QM that looks promising:
Will try to meet up with D&G to check this one out if thats possible.
