Changing the Differential Fluid
Are the diff drain plug’s magnetic to help trap the fine metallic material in the oil?
Can't speak for the drain plug as not touched it but the fill plug certainly has a strong magnet. Saved me dropping it once. Presume both are the same.
I just changed mine using Titan 80w90. The front had 2.1L and the rear about 2.05L. I filled both with 2.1L. The oil looked pretty clean (only have less than 5000 miles).
