Brake fluid flush
Gxgn
10:23 PM
Iowa, USA
Hello, has anyone done a brake fluid flush himself, not at the dealer? Do you know if there is a system reset procedure if you tackle this project to avoid a long drive to the dealer? My brake pedal holds too close too the floor for my liking and I think a brake flush would help.
Thanks
Thanks
Currently no way to do a reset without dealer doing it for you. However the braking system is typical except has a manual rear break aka the brake lever, so no need to home the rear brake if you are doing a pad swap your self. Anyway yes you can bleed or vacuum bleed like normal. Mine is actually really hard or I would be doing what you are asking, bc I hate sloppy brake paddles.
I’m not sure, I watched a few videos on BMW brake fluid change and they had to do a system reset (without a dealer visit) and wanted to check if that’s the case for Ineos too.
Yeah so there are actually two, the one you probably seen was when the vehicle gets to either pad sensors or mileage for the fluid needing changed. You will need to go to the dealer to get that reset with the Ineos. The other is actually homing the electronic rear brake, which we don't have so you are all good. (FYI the electronic ones for BMW can be done by hand no need for a scanner tool to reset them).
So if you are just going to bleed or swap fluid you don't have anything to worry about. Just get it done.
