Considering I’ve been up there a dozen times in my Toyotas (that never had this issue FWIW), I will be doing this trail again in the future lol.Go up again and see if happens the second time!
Would the available display of Tire Temperature reflect added heat from the brake system (i. e. increased temperature observed after significant use of brakes)?Great point. Especially considering that this scenario consisted of sub freezing temps, snow, and icy puddles.
You would think that brake and engine oil temps would be in the temp screen in the off-road menu. I care way less about my tire temps than I do the critical fluids.![]()
Retract my comment. I was coming down Deer Creek 10 days ago. No snow or ice. I don't think that incline would heat up your brakes, I have been there 3x this year with 5 Grenadiers. No one had an issue. But maybe the ice did it, I have zero experience with ice. But also the sub zero should have mitigated it some. It is worth asking Red Noland to as Ineos, what causes the warning. Heat? Too much slipping? The software engineers aren't the best. Was it even real, or a software glitch. It is dangerous.Great point. Especially considering that this scenario consisted of sub freezing temps, snow, and icy puddles.
Oil temperature is displayed in the off road screen on the B57 diesel engine version. Which isn't helpful in the US where you only get the B58.Great point. Especially considering that this scenario consisted of sub freezing temps, snow, and icy puddles.
Thank for affirming this. I have 10+ years experience driving these roads and never once felt I was abusing the brakes. I’ve driven this particular road a dozen times in my Toyotas and never had an issue like this. I’m trying not to take offense at the comments “ride a lower gear”Retract my comment. I was coming down Deer Creek 10 days ago. No snow or ice. I don't think that incline would heat up your brakes, I have been there 3x this year with 5 Grenadiers. No one had an issue. But maybe the ice did it, I have zero experience with ice. But also the sub zero should have mitigated it some. It is worth asking Red Noland to as Ineos, what causes the warning. Heat? Too much slipping? The software engineers aren't the best. Was it even real, or a software glitch. It is dangerous.
You're right. Downhill Assist uses the brakes, so it can cause them to heat up on a long, icy slope. It's not meant for that.The downhill assist uses the brakes as well. I never had to use a DA on icy roads, but if the brake system heats up, that could also happen with the DA, as it also uses the brakes. Maybe you need to take other measures, as the DA is not designated to go down icy tracks.
Maybe it would be better to use snow chains and winter tires (if not already done) or tire spikes. Every system has its limit and a steep, icy track may be over the limit of every system.
FTR, DA was on for 50 feet just to get through the tough corner. I’m 90% sure the brakes did not overheat. I’ll talk with my dealer tomorrow to understand more. I’ll post a follow-up.You're right. Downhill Assist uses the brakes, so it can cause them to heat up on a long, icy slope. It's not meant for that.
For a steep, icy track, your best bet is proper tires. Snow chains or tire spikes are the real solution for that kind of condition.
Throw in a slushy wheel speed sensor and it's not hard to see a system condition that the BCM cannot process so it throws the toys out of the pram.My first thought before the mention of brake overheating was a situation the software had difficulty processing. Could the right combination of having DA on, feathering the brake, the surface condition, wheel slip, steer angle, pitch and yaw with the brake traction control be enough to find that point the software causes the ABS /traction module to activate in an unexpected way for the situation? A situation where the holes line up and is difficult to replicate.
@Brad@SuperiorCO
It’s just little moments like these that make the trail puckery FWIW. It might not be bad if we get some warm days w/o snow.
(Not to derail the convo)
@Clark Kent @NQ94 This seems to be the most plausible. Not confidence inspiring. We’ll see what the dealer has to say.
255/85r17 MT Baja Boss AT2 @ 10PSI.I assume that is ice ahead… did you say what kind of tires you were running?
As for descent control, what is that good for- the sweet spot for its use? We used it in the Red Noland 101 off road class, but is it better low gear and careful braking. Depends on the car, but sometimes I think auto systems like anti-lock braking have issues in low traction scenarios. And if the system is constantly differentially braking, then I could see it building some heat.
I parked up on that ridge once off the shelf road, probably at 10° pitch 20° roll, or greater. When I started the Gren, I had all types of errors for 15 min, until I could get to a flat spot and restart. It didn't do well. But the brakes were fine. I guess the software engineers IG used just aren't the best.255/85r17 MT Baja Boss AT2 @ 10PSI.
Low 1-2 was used for the descent in an effort to keep the tires rolling. More throttle was used than braking.
DA was used for 50 feet through the odd corner triggering the malfunction. The thought process was that it MIGHT do a better job at keeping the tires rolling than I where brake application was needed. The corner was relatively low-stakes and an interesting experiment for the system.
John at Red Nolan had not heard of this issue before. He called his engineer who had not heard of this happening either and was unable to explain. They are researching the technicalities of the system today and said they will reach back out to me. John said it sounded to him like a software malfunction considering the unique situation (steep pitch & roll, low traction environment, low range locked, off road mode, and the engagement of DA).
Software is the necessary evil in these things. Frustrating.I parked up on that ridge once off the shelf road, probably at 10° pitch 20° roll, or greater. When I started the Gren, I had all types of errors for 15 min, until I could get to a flat spot and restart. It didn't do well. But the brakes were fine. I guess the software engineers IG used just aren't the best.
Locked? The center diff or rear (and front)?255/85r17 MT Baja Boss AT2 @ 10PSI.
Center onlyLocked? The center diff or rear (and front)?
I don't know either, but given this is v1.0 of a new platform built by a v1.0 car company it's unsurprising. I want to think that systems like ABS are off the shelf with calibration applied to suit the vehicle dynamics. Same for BMW's DME/DDE (ECU), ZF's transmission ECU (TCM), etc. All are mature systems that work well in isolation. Throw them together with a bunch of odd-fellows that have not been integrated in the same combination before like body control, HVAC, ICE and security there is probably going to be a few bugs to work through. And that's just the base config before branching occurs for market regionalisation. The update process may go on for a while yet.As someone in the software industry, I wonder if the problem isn't that Ineos hired poor software developers, but rather that they're trying to cram 40 years of ABS development into a 3-5 year dev cycle, starting from scratch? I don't know, but it sounds like there's a bit of re-inventing the wheel going on with software and this vehicle.
I totally agree. And throw in the regulatory cycle for clearance, it is probably more like a 1-3 year effort to first release. I have no complaints, I am happy for what it is. I have had so much fun the past year.As someone in the software industry, I wonder if the problem isn't that Ineos hired poor software developers, but rather that they're trying to cram 40 years of ABS development into a 3-5 year dev cycle, starting from scratch? I don't know, but it sounds like there's a bit of re-inventing the wheel going on with software and this vehicle.
