Bonnet solar panel
Tjeska
Quartermaster Owner
10:07 PM
Oostende, België
Does anyone has experience with these PV panels?
Lensun Solar
I don't like flex panels that much because they just aren't that robust and can develop microcracks (thermal expansion).
Would like to know of anyone here has such ones, it seems like a good idea to cover the otherwise unused real estate of the bonnet.
Is it mounted directly to the bonnet? Is there no ventilation and cooling needed from the backside? How does the heat from the motor affect the efficiency of the panel? A lot of Pesos for 90W. Is it worth it?
I've had bonnet solar on several vehicles now; and actually ordered the Lensun kit several months ago, only to find out that they in fact didn't have a kit for the Grenadier at that time, despite what their website said (they needed all the bonnet measurements). According to my last email from them (middle of June), they do have the appropriate measurements, and were expecting the panels to be available in July. Not sure if that is still the case or not.
My previous experience with bonnet mounted solar is using panels from Cascadia 4x4, with good results. We have their panels on our Sprinter (for about 2 years), and had them on my better half's Tacoma for about a year until it was sold. The Tacoma's panel appeared to be delaminating in a few places (maybe 5-8mm areas), but worked perfectly fine.
@chrsbe yes they are mounted directly to the hood surface (technically they suggest a layer of vinyl to protect the paint from any flex in the panel); and while I'm sure there is some negative effect from constant heat, the panels aren't intended to be super high producers, more so just a little bonus bump.
If you have room to put a panel elsewhere, I would prioritize that first as your price-per-watt will be vastly cheaper; but if it is all the space you have for solar, something is better than nothing.
One thing to caution is their panel voltage is a bit too low if you plan on using a Victron solar charge controller.
Has anyone with a Lensun bonnet/hood panel tried to fit a suction cup camera mount on the solar panel? I use an Insta360 camera mount to film my trips and I'm concerned the surface of the panel will prevent a good suction grip.
Why not put it off-center, on the free area and angle it towards the center. Given it's a 360 camera, a couple inches shouldn't make much difference.
I looked at the Lensun but the Watt:Effort ratio was pretty low. I’m putting 200W on the roof instead, but also have a fridge in back.
@LabRat Thats worth trying!
Lensun have confirmed by email: "We don’t recommend using suction cup mounts directly on the surface of our solar panels. While the panel is durable, its surface isn't designed for repeated suction use."
So now we know.
I made the same calculation.
I have a rollout solar from bug out solar that fits my hood perfectly. Not quite as good as a permanent mount but will work well for me. And better output.
Yea, but this to me is battery topper, not a primary source, and I want to keep my top free, as I frequently toss things up there. On the other hand, if I didn't actually need roof load capability, I think I'd still use the lensun, as the cost delta over time for having mucked up the airflow over the top would balance it all out. It's amazing what a roof rack costs ya if you're at freeway speeds frequently. I think the $$ difference is made up in the function of utilizing otherwise useless space v. clogging useful space.
True, but my full length roof rack currently offers more space than I need. And with the fridge I’m much happier having 200W, considering extended stationary use.
No room left on my roof for a panel, so the Lensun was it. The outfit out of Canada doesn't have anything for the IG, Lensun did. My Dometic CF50 is wired to the aux battery - I might change that at some point, but the 90W panel does well keeping my topped up.
Are those battery readings from a smart shunt and if so do you have one for each battery ?
