Black Sheep Inovations
TheDocAUS
9:20 AM
Eromanga
So Mike - this Rhino rack has been specifically developed for the Grenadier but do we know what the specific changes Rhino made for the Grenadier rack?
The size of the roof rack was customised to the IG's roof size, using a pro forma style used for the Pioneer Platform on many different cars. So if looks bascially the same as the one on my Patrol, but just bigger.
The attachment points are different to many other models of the Pioneer Platform. My Nissan Patrol had 6 attachment points, the IG has 8. Also the style and shape of the IG attachment points is different from many other models I have seen. I noticed that straight away, but I like the new style on the IG.
Pat-Ard
Global Grenadier #00520
1:20 AM
I asked BSI after the dynamic load of the platform. They said 100kg for each platform…
ADVAW8S
Global Grenadier 0044
4:20 PM
Kirkland, WA, USA
In that case Frontrunner has now moved into second place for me and Black Sheep has hit the lead
I agree, I am thinking hard about BSI rack. I've been researching the L track heavy duty attachment options.
Xrford
4:20 PM
BC, Canada
what is the dynamic load of the two combined? If they say 200kg then that would exceed the dynamic roof load of the Grenadier, so not sure how a rack can exceed the dynamic load of the substructure it is attached to. I also would ask the question if the rating is lower for off road use?
das mo
1:20 AM
Loading your car you always go by the weakest component. As the third element is just put in-between the other 2 without extra legs, it still is only 200kg with the Grenadier with 150kg being less, so never load more than 150kg driving. If you go off-road the 150 probably is more 100kg to respect the additional force.
12:20 AM
It's not just attached (if indeed it is) to the roof, it's also attached to the tie down bars ~ so some load may be imparted through both?
Logsplitter
12:20 AM
That’s a good point. Maybe when serious off-roading. Then a Couple of ratchet straps thrown across the top of the rhino rack and fixed to to the tie down bars would be extra security 👍🏼
das mo
1:20 AM
Are you suggesting we can increase the dynamic load limit of the IG distributing load onto tie down bars as well as the gutters? If not, the BSI rack will never be the weakest link here, so it is safe to use with up the allowed 150kg.
Xrford
4:20 PM
BC, Canada
The Grenadier has a dynamic roof load rating of 150kg, that means any structure above the top of the door (ie the roof structure)is rated to handle max 150kg Cargo with the weight born by the roof. The grab handles were designed to be a lashing point for the roof cargo and were never designed to support roof cargo so the forces put through the grab handles for lashing cargo down are totally different than the forces for supporting the weight of the cargo. The crux of the matter is the load you attach to the roof in total (including the mass of the rack) should be either the racks design limit or the 150kg limit of the Grenadier, which ever is the lesser. No additional support you add to the rack will allow you to exceed the 150kg limit, in fact it will just take away from your cargo as you are adding weight.
9:20 AM
There has been many cases in Australia where brands such as Rhino have failed off road and the owner is not covered by insurance.
They have on their website that you have to derate by 50% for off road use.
9:20 AM
The Grenadier has a dynamic roof load rating of 150kg, that means any structure above the top of the door is rated to handle max 150kg Cargo with the weight born by the roof. The grab handles were designed to be a lashing point for the roof cargo and were never designed to support roof cargo so the forces put through the grab handles for lashing cargo down are totally different than the forces for supporting the weight of the cargo. The crux of the matter is the load you attach to roof in total (including the mass of the rack) should be either the racks design limit or the 150kg limit of the Grenadier, which ever is lesser. No additional support you add to the rack will allow you to exceed the 150kg limit, in fact it will just take away from your cargo as you are adding weight.
Exactly
So 150kg
Minus 60kg for the overweight Rhino rack leaves 90kg
derated by 50% offroad leaves 45kg.
If you can find a roof top tent that only weighs 45kg please post it.
Logsplitter
12:20 AM
The Grenadier has a dynamic roof load rating of 150kg, that means any structure above the top of the door is rated to handle max 150kg Cargo with the weight born by the roof. The grab handles were designed to be a lashing point for the roof cargo and were never designed to support roof cargo so the forces put through the grab handles for lashing cargo down are totally different than the forces for supporting the weight of the cargo. The crux of the matter is the load you attach to the roof in total (including the mass of the rack) should be either the racks design limit or the 150kg limit of the Grenadier, which ever is the lesser. No additional support you add to the rack will allow you to exceed the 150kg limit, in fact it will just take away from your cargo as you are adding weight.
yes thanks. I get that but surmising extra fixing with ratchet straps would help off road. Just a thought. I just hope the gutter rails are stronger the original defenders s they are sagging on mine
das mo
1:20 AM
Exactly
So 150kg
That is why nobody will end up driving a full rack around under a tent.
I am almost done with my plans. My solution will be based on three pairs of these.
https://daysontracks.com/pages/roof-rack
The top base is 120x80mm in size made from 4mm steel. Slotted for 8mm screws.
So I will use regular 40x40 or 40x80 mm alloy bars across the roof and have some 40x40 ones on the side. Feet come with airline / utility fixing option.
With few of these profiles at home, it allows me to lengthen and shorten the rack as needed and build / fix everything with cheap 8mm screws and material that is available all around Europe.
A pair of these high gutter mount, spacing to the rubber thingies on the IG roof is 30mm, weights 2,5kg. Profiled are 1,5kg per meter. So I should be able to put this together in the 25-30kg range easily.
Might even have an extended frame running around and between the safari windows to allow extra loading when needed.
And if I end up travelling without my RTT, I can fix panels on top with some 8mm bolts.
What do you think? Any major concerns?
Xrford
4:20 PM
BC, Canada
Exactly
So 150kg
Would it not be 150kg load limit of the rack at 50% which is 75 kg
load limit of the roof is (150 - rack 60) =90 kg so the lesser of the two would be 75kg you need a tent less than 75kg
das mo
1:20 AM
Yeah. I gave the gutters at the dealer a solid shake and was semi-confident these will hold our family of 4 in stormy nights.
Do we have written confirmation on all sections of the gutters are equally strong or there being sections to prefer?
9:20 AM
Looks like a good solution
Unfortunately/fortunately you are not allowed to build your own roof rack in Australia
9:20 AM
That is possible as Rhino just states the load rating needs to be de-rated by up to 50% but then doesn't clarify.
I find it a bit hard to believe that their rack weighs exactly 90kg
