Auxiliary battery. Confused
Howard
Forum Supporter
9:21 AM
Banbury, UK
I am a bit confused. Apart from the obvious extra battery and split charger what else does the auxiliary battery option include. Do you get any pre wired switches or additional outlets?
The additional switches and circuits come from the High Power Aux Switch option, not aux battery option.
The INEOS website description of the Aux Battery option tells you nothing (which I assume is why your need to ask).
It may include the second 5 stud busbar and I am not sure if it also includes the CTEK120S. I do not know for sure as I have a dual setup.
the way they did it is that they made two batteries behave as one.
You don't get separate switches etc on the second battery, you get the second battery added to the first battery as additional capacity.
So does the basic truck come with and spare overhead switches?
Take as look at the Rok Dr Guide it answers that question and many others. @Rok_Dr
These links may also help. EDIT: updated links now here.
PLACE TO START FOR NEW OWNERS
  1. Download and use the Rok Dr Guide here. Print out a copy and keep it in the car;
  2. Grenadier Accessories (huge selection) for you to buy here;
  3. Kanvas bags and products here;
  4. Information concerning Deutsch DTP plugs here;
  5. Learn more about the CTEK SMARTPASS 120S and 250SE here;
  6. Fuse and relay thread here;
  7. Suggested Grenadier or QM fuses spares kit here;
  8. Littelfuse FHZ busbars used in the Grenadier here. It also informs you where all the busbar cables go;
  9. Finding the aux power outlets in the footwells here;
  10. Table describing all the available wire ends here (more wire ends if you selected the high aux power option);
  11. Various recommended torque settings here;
  12. Tool kits for the Grenadier/QM discussed here and here;
  13. L track information here;
  14. Oil filter part numbers and third party filters here;
  15. INEOS Air filter parts numbers and cabin filter here;
  16. Filter for Diesel water separator here;
  17. Understanding the NATO plug on the Grenadier here;
  18. What do you use on bolts/screws to stop corrosion, galling and seizing here;
  19. Guide to terminal crimping here;
  20. Anderson plug pitfalls here;
  21. Outback driving tips here; and
  22. Cheap battery monitors here.
Thank you guys excellent support as always.
I have purchased a pre built new Gren commercial (UK) which has the auxiliary battery option and thought it included roof top socket outlets. It's not a problem but wish the Ineos web was more detailed.
Also included is ruff and smooth pack, rear ladder, tow pack , alt - compass and leather seats. It's Inky black running on steels with Bfg's.
I have also purchased a secondhand set of unused 17" alloys and Rock sliders as well as a spare wheel storage box.
Hopefully take delivery next week.
Then I will add these as well:
INSTALLATION (OR HOW TO) GUIDES
  1. SEAT COVERS: Canny Outdoors video fitting seat covers here;
  2. SPOT LIGHT REPLACEMENTS: Mounting Kit of Exezit Lights here and KC Hilites here;
  3. SIDE MIRRORS: Installing SUMA Performance side mirrors here;
  4. WORKLIGHTS: XHQ Work light here, with installation instructions here, STEDI Work light here and here;
  5. RETROFITTING A RED WINCH: Installation guide here;
  6. REAR ROOF SHELF: Canny Outdoors video installing KAON rear roof shelf here and a Travel Buddy oven fitted to a rear shelf here;
  7. ROCK SLIDERS (ABNTR4X4): Installation video for ABNTR4x4 Rock Sliders here, with suggested improvements for tougher environments here;
  8. ROO BAR: Installing the Roo Bar here;
  9. ROO BAR LED LIGHTBAR: Installing a 20 inch Lightforce Viper lightbar under the Roo Bar Hoop here;
  10. UHF (CB) RADIO: How to install a UHF (CB) Radio in an INEOS Grenadier without drilling any holes here;
  11. UNDER-BODY ARMOR (RIVAL): Installing Rival under-body armor here;
  12. UNDER-BODY ARMOR (CUSTOM OFFROAD) BASH PLATES: The installation thread is here;
  13. UNDER-BODY ARMOR (CUSTOM OFFROAD DIFF PROTECTORS): Installing the diff protectors and trailing arm protectors is here and the PDF here;
  14. UNDER-BODY ARMOR (ERO FLO FUEL FILTER GUARD): The installation thread is here and the PDF here;
  15. SIDE STEPS: Electric side steps installation guide here;
  16. INSTALLING AFTERMARKET SPEAKERS IN FRONT DOORS: instructions here, German language install here;
  17. INSTALLING BLACK SHEEP NUMBER PLATE HOLDER (US/AU models with OEM winches) here;
  18. INSTALLING REDARC TowPro Elite3: look here;
  19. INSTALLING THE WOLF G900 DASHCAM: Loc Nar's detailed installation guide here;
  20. B PILLAR (DISASSEMBLING): look here with detailed instructions here;
  21. INGEMAR’S GRENADIER HOW TO SERIES here and here (e.g winching, offroad modes, diffs, etc);
  22. INEOS FORUM resources here;
  23. INEOS Fitting Guides here, at least 9 guides from INEOS and Rhino Rack.
Regarding the ble battery monitor how would that fit onto an early trialmaster with dual batteries any info would be appreciated
The BLE fits on my dual battery Trialmaster. I have one on each battery, giving 2 in total.
You just need some double sided tape or Velcro to hold the unit to the BLE to the battery - I use Velcro for easy removal and reattachment.
thanks that's exactly the info i wanted now just to find the BLE ones . cheers
The Ancel will also fit, but I found the BLE to be more accurate for my use.
With the BLE run the wires under the battery holding bracket and be careful about placement, as the wires only just reach to the terminals. It is a snug fit.
I loosened the secondary battery nut (from memory) and slid the BLE's U terminals over the bolt and then tightened. That way I did not lose any nuts under the seat.
thanks for the help I've ordered two of the ble ones from ebay , the dual battery setup is confusing to say the least .
Confusing enough that dual battery is no longer an option you can order.. 😟
