- Local time
- 9:21 AM
- Joined
- Sep 4, 2022
- Messages
- 76
Has anybody found aux outlets in footwells,under bonnet and fusebox.Had a quick look but cant see anything obvious.Do you have to remove covers.Quick start guide very vague not a good picture.
Already have lighting in footwells.Want touse aux sockets
The brown led is permanently live (40amp Fuse F113), black is ground and the yellow is switched on with the ignition.I think the third is an ignition source, but not 100% sure.
Can I assume you meanThe brown led is permanently live (40amp Fuse F113), black is found and the yellow is switched on with the ignition.
I connected the ARB compressor to these wires
The brown lead (cable?) .......
Black is Ground???
Sorry if I wasn’t clear enoughI have only seen the same image. Someone else on the site suggested the ignition source, but I cannot find that link now.
Brown is the third, as white/cream and black are the other two.
ThanksSorry if I wasn’t clear enough
There are three wires (cables or leads if you prefer)
The brown wire is heavy duty and is permanently live. It is on fuse F113 (40amp).
The black wire is the associated earth (or ground if you prefer)
The yellow wire is live with the ignition.
I connected my compressor up to these three wires earlier today.
Hope that clarifies a bit for you
Why did you use all three? Did you use a relay to make live only with ignition on?Sorry if I wasn’t clear enough
This forum is amazing,thanks for your help.Have you found the ones under bonnet yet.Want to weigh up my options for i commit to wiring.ThankdI think the third is an ignition source, but not 100% sure.
It has been found, looking for the link now, Jean Mercier found it.This forum is amazing,thanks for your help.Have you found the ones under bonnet yet.Want to weigh up my options for i commit to wiring.Thankd
Hi. Please can you send some pics of the ARB compressor installation?Thanks
I like your compressor install.
Looks like a neat solution
Is this what you are looking for Larry?Hi. Please can you send some pics of the ARB compressor installation?
Thanks
You beat me on this, this was my next goal, DTP connectors on these wires.However, the 25 amp socket has no voltage. I assume that this is related to the software issue in connection with the missing front winch and the Nato socket. This currently has no voltage either if you have not fitted a front winch. I will clarify this later.
And do you have voltage on the 25amp socket? With or without front winch?
