Aux Power not going to vehicle outlets when ignition is off.
The statement on pg 34 means the DC outlets (12v), not the inverter.
As with (almost) every factory installed inverter, it requires the vehicle to be running to work. With the vehicle running there is no appreciable drop in battery State of Charge because the alternator is there to recharge, and thus allow nearly indefinite power output from the inverter.
I'm sure this could be bypassed (fairly) easily, but could put you in the spot of a main battery below 50% state of charge and thus reducing its capability (and lifespan).
This shouldn’t be this hard.
We need Ineos to give us a definitive answer. Has anyone reached out and confirmed that the inverters aren’t designed to be turned on by the PWR switch? I find this a bit backwards. Especially for those of us with the dual battery setup. I’d like to use the outlets to power some minor 110v things without running the engine. Why would this not be allowed, especially if you have the dual battery setup?
Because the way the factory dual battery works isn't traditional. Accessories are wired to the main battery, not the aux battery. The aux battery serves two purposes: 1) to trickle (pulse is more accurate I believe) charge the main battery as it depletes. 2) to be a "jump start assist" in the event that the main battery is depleted and cannot start.
Most aftermarket dual battery systems wire everything to the aux battery, and nothing but essential vehicle functions to the main battery.
The power used by the inverter is a substantially greater amount than the SmartPass120 can handle keeping up with through the trickle/pulse charging.
I'm not saying that I feel like they did this correctly, or justifying their choices (or giving a reason for why the configurator says one thing and in reality it is different); but this is what I can gather based on what I have found of the electrical system in place.
I'd be happy to be corrected or proven wrong on all of this
So, do you know if the system as it currently is configured will have any failsafe built in if we are pulling energy from the DC outlets? Like if I plug a DC-powered Fridge into the outlets would it drain the batteries until the engine won't start, or is there sort of failsafe that would cut the DC and over auxiliary power first ?
I think the failsafe you are looking for is a low voltage disconnect.... I'm not sure if this logic is built into the PWR switch (to enable the outlets w/o ignition power).
Beyond that, I think the SmartPass will stop trickle charging the main battery when the aux battery reaches a low-ish state (unless required to connect both for a starting attempt); but I'd want to read through the documentation one more time before saying anything is a fact.
On the plus side, given that you have a theoretical ~90Ah to use across both batteries, that's something like 20 hours of compressor run time for a fridge, which should equate to something like 60 clock hours without starting the vehicle. Of course, this is dependent on ambient temps and fridge set temps.
borrowing this thread;
Which outlets are supposed to run on the aux battery when switched on?
In my case the 12V in the cargo area works, so does the USB-A/C in the rear passenger seat. But not the USB-A/C in the “glove box” between driver and front passenger seat.
Is that how it’s supposed to work?
This is how mine works too. It’s really frustrating the usb a/c inside the center console (you know, the one most likely to charge the drivers phone) doesn’t work with the switch.
It’s super convenient to be able to flip a switch and be able to keep charging a phone when we go to a kids game or store, etc. but then I have to unplug the cable and plug it in to the one in the rear seat.
Ok further to this.
I thought i was going insane!!!!
I 10/10 swear my front glove box sockets worked when the pwr switch was activated and vehicle off. As mentioned above the normal smart and logical way any person would expect it to work. This was when i first got the car September 2023.
I am having some service work done now and The team assured me the rear passenger ports do work and the fronts are not meant to. They checked other vehicles at the dealership to confirm this as did I.
The frustrating thing for me is prior to the last recall works done (late march 2024) the front ports were supplying power when pwr switched on but car off.
This is ridiculous in my eyes, can we get some form of confirmation that it was an intentional change and why?
Like others have said
so Frustrating to have to remove the cable and plug to the rear slots for this feature to work
Where as the rear 12 volt works as expected…..
It makes a cool feature that absolutely was a reason for my purchase become another pain just to make the most out of.
From how it has been explained to me, the front ports are powered through the headunit/infotainment, thus the PWR switch has no effect on them. This shouldn't have been a software related switch, because there is no software logic to how the PWR switch functions
Ah ok… that too makes sense,
Strange but makes sense.
Would also explain why it works at times with car off, eg stoped to pick someone up, turn motor off an flick switch above to power but perhaps the stereo did the powering?
will check when I get my vehicle back, either way am serious tempted to swap the power supply from the passanger seat to the glove box and vice versa so i get the logical outcome others here and I myself expect.
The front console usb ports remain powered for a couple of minutes aftershut down....until you open the driver's door.... then they immediately power off. At least that has been my experience since I got the vehicle a year ago.
Some additional differences between the usb ports in the centre console and those on the rear of the console.
Both centre console ports support USB2.0 data transfer speeds. They support the BC1.2 charging standard for compliant devices (up to 1.5 Amp).
The optional USB ports installed on the rear of the centre console are for charging only, they have no data functionality. The USB A port has a 2.4 amp output. The USB C port has a 3 amp output.
Cheers
Steve
Cheers
Steve
Thanks for posting this. The rear USB's are the logical charge ports.
I use the rear to charge my phone because I think it's easier - the charge being faster is just a bonus IMO. We installed a pair of ports on the passenger side for the wife over the weekend, wired to INT2.
Mind sharing a pic and what product you used? I like that idea too
I am trying to trouble shoot why my 120v outlets dont have any power to them when key is ON or OFF and whether MAIN PWR switch is ON or OFF. During testing I found that the USB receptacles in console are tied to MAIN PWR so I can turn them on when key is off in Grenny. Same for 2nd Row USB outlets. I hear the click in inverter when I switch on MAIN POWER but is NOTHING going to 120v receptacles. Anyone identified a fuze, relay, switch, etc that needs to be activated to allow....??
Start the vehicle, does the inverter work then?
What I found when when wiring up the Wolfbox and extra USB port, are that fuses FC21, FC22, and FC23 (located to the right of your steering column (LHD)) are all constant power when the overhead Power switch is on (Pictures are from @Loc Nar build thread). Which means the front center console USB/cigarette light socket, and rear plugs should have power.
Check to see if any of the 3 fuses on the right column are blown.
I will....but thought the 120v would likely only be fused through inverter due to power limits....will check just to make sure. The USB ports all work it is only the 120v receptacles that are inoperative. Thank you.
