AUSTRALIA: Third Party Suppliers for the INEOS Grenadier and QM
Switch Boss added at No2 (thanks to @pedrogb)
SWITCHES, SWITCH PANELS, HOUSINGS, ETC.
Many of switches seen on 4X4s are Carling type switches (now owned by Littelfuse) also called rocker switches. Australian sources of these switches include:
  1. Lightforce, which has an extensive range of switches and switch panels, including custom printed switches, switch fascias (panels), USB chargers, UHF passthroughs, etc;
  2. Switch Boss has a huge range of switches, USB sockets and panels here;
  3. SAAS, which has an extensive range of switches and switch panels, especially Carling Panels;
  4. Kenay Kustoms switches and switch panels here;
  5. STEDI, which has an extensive range of switches and panels;
  6. Baintech, rocker switch panels;
  7. Enerdrive, water resistant rocker switches. Which I think are made by Blueseas Systems who also make Condura Switches, Toggle Switches, Rocker Switches and Rotary Switches;
  8. Brown Davis DIY powerboard;
  9. HULK connectors, panels and housings. Also switch panels;
  10. DRIFTA Stockton Control Box, Mini Power Box and Distribution Panel;
  11. Some upmarket switches from the US here;
  12. Narva, with both switches and panels, like Sealed LED rocker switches, OEM styles switches, Toggle Switches and more; and
  13. Specialist panels like Razed Products panel for your air compressor switch and outlet, UHF pass through adapter by GME, etc.
LINKS ADDED
New links added, being 12 and 15.
I have now bought the Smart Touring Systems Starlink MIni Mount (key lockable) here, demo video here. I will need it if I got to the Kimberley.
STARLINK MINI BRACKETS/MOUNTS
  1. SVNTY Starlink Mini Mounts here;
  2. 4X4 Lab has various mounting options for different roof racks here;
  3. Outback Comms vehicle mount here;
  4. Outcamp mounts here;
  5. DV Mechanics here;
  6. BA Starlink Mini mount here and new lockable mount here;
  7. KAON Starlink mounts here;
  8. Pirate Camp Co Starlink Mini Quick Release mount and bracket here and more stuff here;
  9. Starshield Mini Mounts here;
  10. SCRUB KING Starlink Mount here;
  11. Smart Touring Systems Starlink MIni Mount (key lockable) here, demo video here;
  12. Starlink Accessories Australia Mini mounts and accessories here;
  13. All Terrain Action has a large selection of Starlink products here;
  14. MITS Alloy has announced new Starlink Mini Mount here;
  15. StarGear Starlink accessories (more accessories like cables than brackets) here;
  16. Outcamp Starlink mounts here; and
  17. Dishy Mini Mounts here (and lots of other Starlink stuff).
I have added some custom lithium battery links, see links 8, 9 and 10. Plus DRIFTA Battery Boxes may no longer be available, KickAss BB's are almost identical.
BATTERY BOXES
Some Battery Boxes reviewed here. The Hardkorr BB was the winner but the DRIFTA, KickAss and Thunder are also compelling (and for some even better).
  1. KickAss Battery Boxes. My mini review here;
  2. KICKASS wired switching canopy power system with 40A DC2DC charger here;
  3. The DRIFTA Battery Box. My mini review here;
  4. Hardkorr Battery Boxes (also marketed as the CAOS Power Battery Box);
  5. Thunder battery box customised by Accelerate Off-Grid Touring, or just the based model Thunder Battery Box here;. Also marketed under the name Drivetech 4x4 Heavy Duty Battery Box - DT-02008. My mini review here;
  6. Thumper Battery Boxes here;
  7. Ardent Battery Boxes here (with 1200W inverter);
  8. Mueller Energy Lithium Battery Box here (no DC to DC charger just a BMS);
  9. PowerPaul Custom Lithium batteries here;
  10. Custom Lithium batteries here;
  11. BMPRO Power Station (with built in inverter and 12 power outlets);
  12. Baintech Lithium Power Tops in 150 AH and 200 AH sizes;
  13. The Adventure King Batblock (assuming it is short for battery block) which comes in 25 amp and 40 amp models. There are packages if you wish to purchase a battery as well, so look (Note: Suitable for unregulated solar panels 10-32 Volts, up to 300 Watts for 25 Amp model and 500Watts for 40 Amp model.);
    JTS Power Easy here;
  14. REDARC GOBLOCK (Premium pricing) here;
  15. EcoFlow DELTA 2 Max (you need an EcoFlow alternator charger to charge at the full rate, the cig socket is limited to 8 amps, thanks @Loc Nar);
  16. Entry level ARK PowerPack 3 here;
  17. The whizzbang POWER BOX Premium range here (3 models, 6 colours). Premium pricing, but high quality;
  18. Not really BB’s, but Enerdrive-Dometic is famous for their 4X4 Canopy Power Systems. More suited to a canopy on the QM Cab Chassis. I am not aware on any install in the IG. A new level of pricing compared to the BB’s. Tool Box Centre offers something (Redarc gear) as does MW Toolboxes (Victron gear) and Projecta Power Boards (Projecta gear);
  19. National Luna Battery boxes here (2 colours), detailed look at the National Luna BB here;
  20. Brown Davis DIY powerboard (5 models);
  21. BMPRO Canopy board here;
  22. REDARC has announced their pre wired power panels called REDworks here. A possible power option for QM owners. It is plug and play.
  23. ORD Battery box for your own DIY job here;
  24. Rok Dr DYI battery controller here; @Rok_Dr
  25. TLR Universal Battery Boxes and trays here;
  26. Battery Box for the DIYer here (by MSA4X4) and Front Runner offers something similar here;
  27. The Power Easy Expedition Battery Box here, with Expedition Weatherproof Lockable Case, DC to DC Charger, AC Charger and Inverter; and
  28. The Accelerate Off Grid Touring Power Grid, these last two options are premium products, with a price to match - both are VERY powerful setups.
GrenX Accessory Rail (RHD car)
Working from the right side I have a GME UHF Mic holder on the angle side (not available on the Own Vans Rail). I can move the UHF hand-piece across from the passenger side holder, when offroad.
I dissembled the GME Mic Holder (Model MB207), drilled a hole in the back plate, inserted a stainless steel 1/4 inch 20 UNC bolt through the hole, reassembled the Mic holder. Put double sided tape on the back and then screwed the ¼ inch 20UNC bolt into the GrenX Rail. The screw driver was just inserted through the opening in the GME Mic Holder. The idea was from Rohan at @GrenX. I did buy 1/2 20UNC bolts but they did not fit into the Mic Mount. The 1/4 bolts fitted perfectly.
Next is the Garmin GPS Tracker.
Far left is the holder for the caravan reversing camera screen, not currently mounted. This reversing camera and the Garmin use RAM Mounts.
Pictures below show the Mic piece moved from the passenger side holder to driver's side holder.
AU GVM and GCM UPGRADES
GVM upgrades for IG and QM, either 4,000kg or 4,495kg with GCM upgrades.
4 inch lift coming later, JMACX are waiting for some components addressing issues like the tailshaft.
Some INEOS dealers in Australia will be offering the JMACX packages.
View: https://youtu.be/Pqnd8yIrhwI
Added Gorilla Mounts products under both headings (Items 4 and 13). Gorilla Mounts are "Crafted from a high-performance nylon synthetic polymer".
STARLINK CARRY BAGS
  1. Crashpad Starlink bags (mini or Gen 3) here;
  2. DRIFTA has 4 different bags for starlink Gen 1, 2 and 3 plus Mini here;
  3. Blacksmith Camping Supplies' Starlink Mini carry bag here;
  4. Gorilla Mounts Starlink Mini PVC carry bag here;
  5. Underkover Starlink carry bags here; and
  6. NAVIGATOR’S Starlink Buddy and TV Transit Buddy (for different Starlink models).
  13. Gorilla Mounts for the Starlink Mini here ("Crafted from a high-performance nylon synthetic polymer");
  14. All Terrain Action has a large selection of Starlink products here;
  15. MITS Alloy has announced new Starlink Mini Mount here;
  16. StarGear Starlink accessories (more accessories like cables than brackets) here;
  17. Outcamp Starlink mounts here; and
  18. Dishy Mini Mounts here (and lots of other Starlink stuff).
Accessory Rails
For US owners Tiny Rig Co now makes an Accessory rail as well, look here. It also has a hole on the angled sides like the GrenX Rail. So only the Owl Vans do not have the extra holes.
ROCK OFF caravan stone guard brush
I bought this Kit today from Busy Bee Brushware in Melbourne. I went their office and they helped worked out what fits on the INEOS Grenadier. The sizing is:
ROK-H-1950-400-E130 Kit
Overall length across the back is 1950mm
Brush trim height is 400mm
1 x Receiver Mount (65mm not the smaller 45mm). Both will fit.
2 x Hitch Brackets
2 x SS 800mm Rails plus fittings
2 x Exhaust Flex hose couplingallows you to put exhaust gas thru the Rock Off guard, otherwise it would melt)
2 x Exhaust Shield Plate and Brush. These mount on the Rock off to allow the exhaust extension pipes to pass through the brush.
The INEOS needs two exhaust pass throughs, one on each side.
Please note my car has:
  1. Eiback lift kit and PolyAir Suspension airbags; and
  2. Allin Tow Hitch.
I cannot install the Kit until I get home. Only then can I bet 100% sure it fits. EDIT: it fits on the Allin tow hitch.
View: https://youtu.be/X6BBWX5sJTk
Euro FLo Australia has announced their side door body armour:
CAMP MATS
  1. Muk Mats, look here;
  2. CGear Multimat, look here. I have used a Multimat for years;
  3. Affordable Camping Mats (made from recycled plastic), look here;
  4. TOUGH AS makes a variety of mats for camping mats, garage mats and other types of mats, look here;
  5. NAVIGATOR’S Mud Buddy and Ground Buddy Mats;
  6. Clark Rubber mats, look here;
  7. EVA Foam Floor Mat to suit Shower/Ensuite Tents, look here; and
  8. The Mountain Design Comfort 5 is a sleeping mat, look here.
House of Tint added as point 1.
CLEAR SKINS/WRAPS/PPF
  1. XPEL PPF film was applied to my car and van at House of Tint Melbourne. Top quality work, no corners were cut.
  2. Purnell Adventure (Sydney) offers a wrap from the dealership, around AUD8.000 in January 2024;
  3. Bushwrapz DIY PPF wrap. Cost AUD660 plus postage for Entry level kit (1 year warranty), two more kits available for more money (5 and 10 year warranty);
  4. Auto Protective Brisbane, PPF (using XPEL) and tinting. Inquire about discounts for INEOS owner by email – hello@autoprotective.com.au, or phone 07 3151 2091 (Contact: Robert Dolley).
  5. Perth Detailing Centre using Bushwrapz.
HOUSE OF TINT AND PAINT PROTECTION MELBOURNE
I recently had XPEL PPF film applied to the IG and the Vista RV Crossover van to prepare for The Kimberley trip. The work was done by House of Tint and Paint Protection at Mitcham in Melbourne, Victoria, AU. They did an outstanding job.
The car and van surfaces were meticulously cleaned and prepared, various trim was removed from the car and van and then the XPEL film was applied.
Finally the edges were heat treated. The heat treatment ensures the film edges do not lift. If the edges lift you get what Rohan from GrenX recently described as a poo line around the car, when fine dust gets under the edge of the film. I understand a few owners have this issue in Melbourne.
Rohan was impressed with the work done on the car, when we met up for lunch.
They are experts in what they do.
Photos here for the car
and here for the van
