AUSTRALIA: Third Party Suppliers for the INEOS Grenadier and QM
Look here:
CTEK D250SE MOUNTING BRACKET
A mounting bracket allowing you to mate the CTEK D250SE to the 120S, options include:
  1. Offroad-Tec Solar Expansion mounting bracket. Compatible with 2 and 5 seater Grenadiers;
  2. If you buy the RedArc TowPro kit from Expedition HQ (packages 2 and 3) that kit has a mounting bracket included for the D250SE, but it only fits a 5 seater Grenadier;
  3. Blacksheep have a 5 seater and 2 seater mounting bracket. Black Sheep Innovations Australia has the 5 seater version now;
  4. EURO FLO Expedition Equipment mounting bracket for the two seater here (5 seater coming);
  5. GPFactor CTEK D250SE Mounting Plate Kit here; and
  6. REDARC ALPHA bracket. MORE4x4 - Dual Battery Bracket Kit (3 brackets) to suit Grenadier/Quartermaster here (not sure if the brackets fit a 2 seater model, so check).
Euro Flo has taken down their offering.
Their is a DIY bracket somewhere.
Looks like you are limited to Black Sheep Australia. Otherwise you need to source outside Australia, although the Offroad Tech has an Australian agent (but is dearer than the Black Sheep bracket).
Reactions: Max
Items 3 and 4 added and 12 and 13 updated:
SUSPENSION FOR THE GRENADIER
  1. Eibach 35mm Pro Lift Kit, look here (Standard, Heavy Duty and Extra Heavy Duty springs available);
  2. Eibach 35mm Pro lift kit/King Shocks package, look here;
  3. Eibach with external reserve oil reservoir here (IG and QM);
  4. Eibach anto roll bar kit here (IG and QM);
  5. King Shocks Set (4), look here;
  6. GrenX has a full suspension upgrade solution using Eibach springs, custom Bilstein shocks, Bilstein steering damper & rear air bags by Poly Air, look here;
  7. AIRBAG MAN suspension for the INEOS Grenadier here;
  8. Dobinson lift kit under development, look here;
  9. SOLVE Offroad using Fox shocks and Eibach springs. Review here by @Braydo;
  10. LeTech Suspension system lift + 40mm (nearly AUD15,000);
  11. LeTech coil springs +40mm;
  12. Oleo-Pneumatic suspension for the INEOS Grenadier, shipped from France, also available at GrenX in AU;
  13. JMACX manual adjustment suspension kit here. Electronic model also available here. Also with INEOS ANZ, look here. You will need to contact JMACX by phone or email;
  14. Tough Dog suspension, springs and dampers here;
  15. TREKFINDER Coil Springs Lift +30 (Progressive Rear & Linear Front) WITH winch;
  16. TREKFINDER Coil Springs Lift +30 (Progressive Rear & Linear Front) WITHOUT winch; AND
  17. Some US suspension options being discussed here.
New Euro Flo Air Intake System. It does not say whether it is sealed or not. Look here:
Bummer! I just ordered the Ineos ones from local dealer. They are a must have in my opinion. As soon as I open the bonnet I put tools or keys or whatever straight down on that spot.
Reactions: CRH
New link added
BULLBAR/WINCHES
  1. INEOS Bullbar;
  2. DMW Bullbar here;
  3. Offroad Animal Predator Bull Bar here;
  4. Offroad Animal Toro Bull Bar here; and
  5. LETECH Winch Attachment here (AU dealer).
Expedition HQ in Australia is now stocking select gear from KAON, Leitner, OWL , Agile Offroad and Lazer Lights. Too many to add to the list, at least in the short term.
With the exception of KAON, most items are expensive.
At least the new Aussie Flag is well priced.
My OEM diff breather values were replaced last week (I had a diff breather kit installed). Even though I have not done water crossings or mud work, the OEM valves were beginning to clog up. GrenX confirmed they have seen this issue before and believe it is causing some of the oil leakages in the diff when the valve clogs up and pressure builds.
I now have a diff breather kit fitted, but if I had the OEM valves I would routinely check they are not clogged up. Simply press them a few times to make sure they are not clogged.
Rohan also mentioned the fitted diff breather hoses were close enough to heat sources on the rear diff and in the engine bay to check for heat damage on the diff breather air lines from time to time. He thought they might deteriorate over the longer term. Great advice. So add this check as well.
My diff breathers are mounted under the bonnet/hood near the air box on a RHD car, not far from the turbo charger. The heat source for the rear diff hose is the exhaust.
Maybe add these check to the Rok Dr Guide @Rok_Dr
For the idiots amongst us (me). Any chance of a picture to show what I need to check. Standard diff breathers
Thanks
Thanks
I would just get under the car, put my had on top of the diff, find the diff valve and press it a few times.
It should move up and down when pressed, mine did off the car. If it is not moving freely it maybe clogging up. Mine were sticking until I did it a few times - again they were off my car when I did it.
Reactions: CRH
