AUSTRALIA: Third Party Suppliers for the INEOS Grenadier and QM
Fire extinguisher bracket
Euro Flo fire extinguisher bracket, can mount Fire Strykers and also a standard style fire extinguisher:
Links Resources update
I have added another 10 links in the Resource section. If the link has XXXX, it is a forthcoming product or I am waiting on a link or new information is expected in that thread or work in progress.
The new links under Heading 2 will be formatted with purple colouring in due course, it just makes it easier to see the new links as they are black, for now.
The INEOS ANZ Cab Chassis "Kaiju" build is at Purnell Adventure in Sydney for a couple of weeks.
I went to Purnell Adventure and had a look at INEOS' Kaiju beast. Some observations:
  1. massive 35 inch tyres, but it works with the lift;
  2. JMACX suspension is really well engineered. The car has an electronic shock controller near the driver, but that option is not offered on the JMACX website (manual only);
  3. it is a beast;
  4. looks like they use a slimline battery behind the RedArc panel - at least that is where all the cables seem to go. Very slick cable work;
  5. Redarc Black Alpha 50A charger;
  6. 2000W RedArc Black Alpha Inverter;
  7. 168 aux fuel tank, with the standard 90 litre - giving 258 litres in total;
  8. Bushmann upright fridge;
  9. STEDI lights on the across the front of the roofrack, above rear doors and in inside and outisde the canopy;
  10. the NORWELD tray/canopy has amazing quality of build;
  11. the setup was around AUD40,000;
  12. it had a GVM upgrade which is going to be must do for any build this size.
My Grenadier has 8 "campaigns" to do, most minor. So booked it in for those and a service. Main campaigns were new door locks, key and the new engine cover, with more insulation so it does not catch fire, plus new firmware.
NEW LINK
Trig Point Slider Steps added (item 2), thanks to @Znarfgh
Trig Point offer QM and Grenadier models at a reasonable cost.
ROCK SLIDERS/SIDE STEPS/SIDE PROTECTION (Grenadier sliders and steps do NOT fit a QM)
  1. INEOS offers rock sliders and steps are an accessory (QM and Grenadier options);
  2. Trig Point Slider Steps here (QM and Grenadier options);
  3. Black Sheep steps that can be fitted to the INEOS Rock Sliders here;
  4. Black Sheep Innovations Australia Steps/Rock sliders here (also XHQ here);
  5. Gren X Rock sliders here;
  6. Jef Fab Customs Rock sliders here;
  7. DMW Rock Sliders here (combination rock slider and step);
  8. ABNTR4x4 Rock Sliders here;
  9. XLW Parts Sill Protector, Rock-Slider and Step here;
  10. LeTech Off-Road Running Board here;
  11. For a global list of rock sliders look here; and
  12. Grenadier sliders and steps do NOT fit the QM. Buy the QM model.
KickAss has up to 50% off on dual battery kits up to midnight tonight.
NEW SINGLE AIR COMPRESSOR MOUNT IS COMING
A new air compressor mount is coming from Euro Flo Expedition. It goes where the jack is stored. Single ARB Air Compressor. I am reliably informed there is a coming Canny Outdoors video on the mounting bracket.
With a 50% jump in air flow with the new ARB brushless compressors, single compressors are becoming a more appealing option, if you do not require redundancy.
Now installed in John Canny's Grenadier. The bracket gets a mention with a photo at 11:20 in his new video. Just click on the video to see it play over at Youtube.
View: https://youtu.be/adgpmgWRv4I?t=685
Reactions: Max
New link added. The Front Runner ladder does NOT offer a Jerry Can holder. Thanks to @beefs
REAR LADDERS (SOME WITH JERRY CAN HOLDER)
  1. GrenX rear ladder with Jerry Can holder here;
  2. LeTech rear ladder with Jerry Can holder from XHQ here; and
  3. Front Runner rear ladder (with NO Jerry Can holder), look here.
  3. it is a beast;
Did they actually do your engine cover? I had my in last week for the door locks and campaigns but they didn’t have stock of the engine cover so mine still to do. Also did you get a list of the campaigns? Normally I get the paperwork but they didn’t give it to me this time.
Car is booked in for 4 Aug.
JOOLCA Autolight for camping
JOOLCA has just released its Autolight, waterproof and magnetic. A very easy DYI option. 4 levels of white and 1 of red.
View: https://youtu.be/aUyasi7fO-8
FAILED BLE BATTERY MONITOR
I had my first BLE battery monitor play up recently. Across the family there is about 8 BLE’s in the field. This is the first one to “fail”.
It was on the IG’s main battery and stopped working about 10 days ago. I replaced it 2 days ago. I could not get it to work, so I opened it up and had a look inside. I touched the resistors and then the monitor started working, suggesting to me vibrations may have damaged a solder connection somewhere. This is what they look like inside:
KAON has also released Rear Window Basket Set to suit the INEOS Grenadier - for soft items only. These new releases all work with their other storage offerings, Watch the video above. KAN has a great range products for the INEOS.
REAR CARGO STORAGE OPTIONS
  1. GGG Molle Panel for the Safari windows here;
  2. EURO FLO Simpson Storage system being tested;
  3. EURO FLO Expedition rear lower shelf here;
  4. Bison Grenadier Basket here;
  5. KAON Rear Side Molle Panels here. Paper Towel Holder to suit KAON Molle Mesh and KAON Rear Roof Shelf, look here;
  6. KAON Molle panels for the Rear Door Windows to suit the Grenadier here. Paper Towel Holder to suit KAON Molle Mesh and KAON Rear Roof Shelf, look here;
  7. KAON also has bags that fit their Molle Panels here and their rear shelves here (See video below);
  8. GrenX Rear Roof Parcel Shelf here;
  9. ORS dual ARB compressor mount that can be used to store things between the board mount and the window, pictures here (you could DIY this yourself);
  10. Offroad-Tec Cargo rack here;
  11. There are also options listed on eBay and Amazon (quite expensive); and
  12. Look also under the heading ROOF SHELF (INTERIOR REAR) here.
View: https://youtu.be/zUd_GzTtiHk
Revised and updated
  1. KAON rear roof shelf here, electrical console for shelf here. Paper Towel Holder to suit KAON Molle Mesh and KAON Rear Roof Shelf, look here;
  2. Bags from KAON for their rear roof shelf here. Unsure whether the bags fit shelfs from other makers;
  3. Get Good Gear Roof Shelf is here. @Kilchoman has one installed. Shelf made by EURO FLO Expedition Equipment and sold by GGG;
  4. Offroad-Tec Cargo rack here;
  5. Bison Gear Rear Roof Shelf (based in Poland, sends products worldwide). Installed on AU Spec car here;
  6. LeTech rear roof compartment here (Super premium pricing). It a compartment rather than a simple shelf; and
  7. APB Trading's rear roof shelf (UK based).
PICNIC TABLE FOR THE REAR 2/3's DOOR
  1. The OEM option from INEOS;
  2. KAON now has a Rear Door Drop Down Table & Door Card to suit the INEOS Grenadier, look here. Chopping board available here, check sizing before buying a chopping board;
  3. US owners can source one from GP FACTOR here; and
  4. DYI option here.
3 new links added.
  6. Jef Fab Customs Rock sliders here and QM here;
  7. DMW Rock Sliders for IG here (combination rock slider and step) and QM here;
  8. DMW Heavy Duty Double Brush rails here. NOTE: It looks like they are only compatible with the DMW Bullbar;
  9. DMW INEOS IG Rear Protection Rails with Bar Corners here;
  10. ABNTR4x4 Rock Sliders here;
  11. XLW Parts Sill Protector, Rock-Slider and Step here;
  12. LeTech Off-Road Running Board here;
  13. For a global list of rock sliders look here; and
  14. Grenadier sliders and steps do NOT fit the QM. Buy the QM model.
