Australia: Battery drain problems
Mkachilli
3:44 AM
Brisbane QLD, Australia
Firstly apologies if this has been already addressed, is there any resolution to the battery drain issue.
I have a 6 month old Grenny that drops at least 10% per day - left it on the driveway for four days when I was away with work and could not start it when I got back, even from a jump start pack from the INEOS roadside assist. The key we’re not kept anywhere near the car.
Tow truck back to the dealer and they recharged the battery over a few days. The dealer said they could not find the drain and that the battery was not faulty.
Been carefully watching the state of charge and there is no logic to the battery drop - no switches left on, no loads left on charge, no Wolfbox mirror or any other parasitic loads.
Must admit it’s affecting my confidence in the car.
Have to leave it at the airport for a week next week and I’m concerned what the battery state is going to be when I get back.
Have found the long term storage advice in Rok_dr’s_IG_manual supplement - but it sounds a bit extreme to remove fuses in a brand new vehicle but I supose it is better than being left stranded at the airport.
Any ideas from the community ??
This is a long shot😉
The public RF band for all manner of "remote" control devices.... weather stations, baby monitors, garage remotes, home automation etc is 433.xxMHz in Australia.
Assuming the Grenadier remote is operating in this frequency band, there may be external RF interference causing the vehicle to be in periodic "constant alert" state. You won't necessarily discover this with normal diagnostics.
You might try locking the vehicle with just the key which doesn't set the alarm. Leave it overnight and measure the drop in battery voltage say after 24 hrs. ...
Years ago I owned a RR P38 which exhibited somewhat similar behaviour. . worse still on occasion I'd hear it unlock/lock continuously for no apparent reason, to the extent it almost burnt out the door lock actuator as well as depleting battery capacity! The culprit was a neighbour's baby monitor 2 doors away. As I recall, the "fix" in this instance was to simply change the operating frequency band via a dip switch on the car's antenna receiver module. The key fob remote apparently accommodated this change "auto-magically" .. end of problem.
As I said . it's a long shot but worth pursuing.
Damned frustrating!😉
I recently found that trickle charging the battery to full, then disconnect the negative terminal, wait 15 mins and reconnect alters the charging profile. It charges quicker than it drains so rather than 1/2 amps at 70%, it will be 5-10 amps. I find this helps but no one knows why it drains so quickly. I find it drains 1-2% per day on my car.
Make sure, if you’re going to disconnect negative terminal, all the interior lights and dashboard lights, time out first (sleep mode).
Interested in a solution as well. Did not drove my grenny for 11 days, and the battery was complety empty. 0%. Could not even lock my doors anymore.
Restarted with jumping cables, and had a check at the ineos dealer. They recharged the battery, but did not found any drain currents.
The dealer even recommended using a smart charger when not driving for a long period. When i asked what is "long", they said a week... which is completely unacceptable for a modern car of this price range.
I am trying to look for patterns for when the battery is loosing the most %, but i havent found a consistent pattern yet.
Any help would be appreciated.
Do you have a dashcam fitted? They are a huge drain on a battery when parked up.
I would let the vehicle go into sleep mode and then one by one remove each fuse and test for amps with a meter across where the fuse used to be. This can at least direct you to the source of the draw.
@matt_grenadier @Mkachilli
Doesn't answer your question and hate my reply as it implies "live with it". So many on this forum have work arounds to HVAC, Electrical, water..... The best answer is "your warranty will cover it and its a five minute fix". In lieu of this maybe something like this might helpful in the short term:
On one occasion mine did not shut down correctly. I heard the faint high pitched noise you get on shut down a couple of hours later.
Any chance that is happening?
I bought a similar item immediately after my New Defender let my partner down HEAVILY and was returned dead to the dealer 180kms away on a flatbed!
Now I never leave home without it and have used it regularly on her Subaru XV, a few times on Lottie our D90 but not yet on Shitake, despite constant battery discharge issues. It’s a strange system but has never let me down.
There are obviously worse electrical problems than mine and I feel for these people but the “quirky” installed two battery/smart alternator setup seems to work for most. 🤞🏽🤞🏽
Love the fuse removal and current check advice above 👆👍🏼
A separate thread here suggesting some issues to look at:
Mine is not my daily driver so I always have a Victron trickle charger plugged in when "stored" - the leads are permanently connected to the main battery positive and chasis ground and both it and the auxilliary battery have Victron bluetooth monitors that show 100% when checked before startup. I also have the CTEK Smartpass 120S fitted, plus a DC/DC charger (set to 30v) charging a 160Ah iTechworld PS2000 via the solar input port, Wolfbox Mirror and a heap of other stuff such as a brake controller and aux fuel tank pump etc. When camping or working on the car I always turn off ignition and then leave the drivers' door open so that the car goes to deep sleep after 15mins - never fully close the drivers' door. With this approach even when camping for several days the battery rarely falls below 85% unless the drivers' door accidently shut. I also carry a jumpstarter - just in case. Without the trickle charger or leaving the door open I lose around 2% per 24hrs of charge.
Mine went to the dealer, and they checked it, but didn't change the battery.
Now the SOC always is around 65-70%, and yet it only charges at 1-2A. I drive it 1hour a week, but it keeps at that SOC of charge. Weird.
I left the aux power switch on while I went away for 8 days, nothing connected at all. Batteries (factory dual) were down to 45% when I got home. There’s a trap for young players. Heaven knows what it would be with a single battery. 😩
Best bet is to always leave it connected to a trickle charger. Then no more flat battery anxiety.
The SOC on the infotainment is the main battery only. The Victron bluetooth battery monitors are inexpensive and when combined with the Victron trickle charger provide peace of mind and you can actually check what the real SOC is for both batteries.
My concern is what is energised when the aux power switch is on. Leaving something energised for a protracted period does bother me. I was going to install an electrical sonic rodent device under the bonnet for when the vehicle is parked up ( mice are a problem) but this issue has curtailed that idea.
Most of the other INT and EXT circuits are activated with the LEDs lit and relays armed and ready to go. All of these will bleed at least a small amount of power.
Mine is now always around 65%, and only charging 1-2A, is that normal? Even after long rides, it barely gets up to 70%.
The gauge is not that accurate if you do too many short drives, for me the charge rate is more important and that looks OK.
The only way I know an owner can reset the SOC is a nice long drive. Mine is stuck around 75% at the moment and I know SOC is higher than that. But today I am dong a nice long drive.
