- Local time
- 10:59 PM
- Joined
- Jul 27, 2022
- Messages
- 6,005
Have a look at CountyV8's Post here, it shows it busbared to the CTEK Smartpass:
Check out CTEK on you tube as wellHave a look at CountyV8's Post here, it shows it busbared to the CTEK Smartpass:
Thank you, but this does not mention the inverter.
We will see if the inverter is fitted when a auxiliary battery is ordered.
It's hard not to see the inverter, as originally previewed, as a production line option rather than an accessory that could be fitted after the fact.
Of course, it could be done but if there's no blank fitted in the back of the cubby box for the plug, then you're into cutting holes or swapping out cubby boxes.
Yes, early ones all seemed to have that dummy/mock up, later ones even had what looked like an actual top hinge cover arrangement:I had thought there was a square knock-out blank at the back of the cubby box specifically to provide a plug socket for an inverter, unless the design has changed.
At the Denver event I told them they needed to run a heavy gauge red back to the trailer plug for charging batteries on trailers. Not sure how they took it but seemed interested. I also mentioned an integrated brake controller so as not to screw one under the dash all janky like but they said no on that. They claim 7,000lbs towing but nothing to control the trailer's brakes? Day one adding an aftermarket brake controller will really mess up the aesthetics. Integrated brake controllers with tow pages have been around for over 10 years.Any updates on alternator voltage? Amps out? Looking at what I will need for charging caravan(RV) on the road.
Here is the Redraw one fitted in Australian cars also there is a NATO plug on the back for the winch that could supply power to trailer.At the Denver event I told them they needed to run a heavy gauge red back to the trailer plug for charging batteries on trailers. Not sure how they took it but seemed interested. I also mentioned an integrated brake controller so as not to screw one under the dash all janky like but they said no on that. They claim 7,000lbs towing but nothing to control the trailer's brakes? Day one adding an aftermarket brake controller will really mess up the aesthetics. Integrated brake controllers with tow pages have been around for over 10 years.
I've been told that the Alternator will have a 250Amp outputAny updates on alternator voltage? Amps out? Looking at what I will need for charging caravan(RV) on the road.
If it is 250A then I think they have done a good thing, as they probably only needed a 180-200A to run the car and charge the starter battery.Any updates on alternator voltage? Amps out? Looking at what I will need for charging caravan(RV) on the road.
