Alternate Aux Battery Proposition?
Mully
8:00 AM
Murray Bridge
Greetings Grenny Gurus! Excellent forum here.
Just this week (in South Australia) got a 12/23 build Trialmaster with the aux battery fitted. Has anyone elected to keep them both as a parallel starter setup (nice that they are matched) BUT re-run the aux devices from a new dedicated aux battery (LiFpo4 etc) with dedicated DCDC charger?
Seems a viable option to retain both installed batteries (210Ah total cap is nice for starter) and just overlay a decent aux setup independent of this.
Interested to hear any thoughts from the Grenny brain trust here as these are one of my initial ponderings before making this setup function.
Cheers.
Cheers.
Not that I have heard. Most replace the aux battery with a Lithium and isolate it from the starter battery.
Although the Redarc Alpha DC to DC chargers can apparently supply a charge to a flat main battery.
I can add a Lithium DRIFTA Battery Box into my car, wired into the aux battery and an ignition source.
Cheers.
Welcome to the forum. One option is to add a portable power station such as a Bluetti power station and add a Buetti dual alternator/solar charger.
Cheers.
I agree with your approach. I've left the original dual battery system alone, (Trialmaster diesel), as its designed function is double redundancy to ensure reliable starting.
As house batteries, I have two x100AH Kings LiFeP04 with a 500A victron shunt mounted in parallel inside a large TACTIX Tough Case (Bunnings). The Tough Case is connected via a short 8 B&S dual cable (50A Anderson connectors) to a diy distribution box housing a 25A DC-DC charger with solar input. Charging is via the 40A cable outlet under the rear seats. The cable's ignition dependent 12v serves as the signal wire for the DC-DC charger to accommodate the vehicle's smart alternator.
Cheers.
After some thought, I did a self made battery box.
Consisting of a 110Ah LifePo, a combined DC and solar MPPT, plus an inverter. Similar to above, charged by an Anderson fly lead when the vehicle is running.
In a pelican style case it is probably the most flexible solution in that it can stay in the vehicle or go in a tent/trailer/caravan depending on the use.
Or you could buy something ready made from Bluetti or similar.
Sounds interesting, I like portable solutions. . Could you send me some details and pictures of what you’ve made up. I made something up in the past for camping with a bison battery box but before the days of LifePo batteries.
A few images. I went DIY so I could upgrade or change components. Also my thoughts were that a typical off the shelf one would not be repairable when it fails.
At about 18kg, probably a bit heavier than I wanted.
PXL_20260120_130530147.jpgPXL_20260120_130502772.jpgPXL_20260120_130456414.MP.jpgPXL_20260120_130451573.jpg
Thanks for the input so far, really appreciated.
I also read often of flat batteries with unattended Grennies which is interesting.
The removable accessory battery option obviously leaves factory wired accessory circuits alone.
Lots to think about and loving the flexibility!
Some of these Battery Box style options are listed below. I just used a KickAss Wiring Kit to wire the DRIFTA Battery Box into the car, off the aux battery. Ignition source was the wire ends under the rear seat (INEOS rear metal box for me in a 2 seater).
KickAss has some Australia Days Specials, look under the heading Dual Battery Box Kits (DRIFTA and Red KA battery boxes are almost identical, the Blue KA battery box has a built in Lithium battery and stunt, it is a slightly different design). They are very good Kits and the Blue 150Ah Kit looks tempting. It is all you need for a DIY install:
Make sure you join the KA Members Club for lower pricing, it is free to join.
I have the red KA kit (with attachedDC-DC charger) but it works fine with a lithium...and it's a lot lighter to lug around! Was happy to offload the AGM to another guy.
The other thing to think about is what capacity you actually need.
A 50A (circa 500wh) battery or power bank will run a compressor fridge for around 24 hours and will be relatively inexpensive, small and portable.
Towards the other end of the spectrum a 200A solution (circa 2000wh) will run a fridge and other things for days, which may be overkill for what you need. It will take up quite a lot of space and eat into your vehicle load capacity.
Processing of options has concluded (I prefer to take a few days before landing on a solution at times 😎) and I'll be replacing the existing aux battery with a Power Paul Cub and rejigging the aux circuits to be run from it. Victron DC to DC for charging and look at adding an MPPT for those days when you are parked up for a while.
I can't get a happy location for the slimline PP Nifty I already have as the rear fit out will likely be modular so the whole space can be made available when not touring etc.
Thanks for all the great input on this folks. Really appreciated and helpful! I'll share some completion pics when done ✅
Looks like a good choice. I might add some PowerPaul links into the list. It looks like he is doing something similar to Muller Energy.
Yeah he makes impressive batteries and his product support I only ever have found goes above and beyond. I've installed a lot of them in off grid jobs and the like, caravans and utes mostly and used them in our own off grid caravan. Can't recommend them enough based on great performing installs.
