Does the pedal tuner work in reverse? That would not be a good thing.
The Pedal tuner works in a very natural way. I use economy #4, I don't have much mileage, Under 300 miles. I use the Pedal and Tiner from IOBox. Reverse seems nornal, nothing different about it.Does the pedal tuner work in reverse? That would not be a good thing.
Did you do the tuner? I assume your not getting faults from the pedal controller.Ok... So I installed this and got a check engine light with the following codes (see picture). I rechecked all connections and may have reversed one. Even after verifying all connections I could not get them to clear for long by clearing the ecm faults with my reader. I put everything back to stock and still can't get them to clear. So at this point I am trying to figure out if the car just needs a min to realize that it is back to stock, I connected a stock connector wrong, or there really is not issue but only the dealer can clear the code. The car runs 100% fine. Just posting here in case anyone else has run into this and has advise.
Yes the IOBOX. Sorry should have specified.Did you do the tuner? I assume your not getting faults from the pedal controller.
You have the cam position sensor plugged in backwards to the IOBOX harness (P0367)... When you are clearing codes make sure the engine isn't running.Yes the IOBOX. Sorry should have specified.
Hey Dave, I just ordered both the ionic and pedal. Curious to know if you ever got to record a video of the IOBox on YouTube. I haven’t found any good ones.This video i made shows you how to install the IO Pedal. I am making one to show tuner install as well but the tuner is even more simple. We sell multiple tuners and the IO pedal. Feel free to call me at our shop Design-Build-Go 704-682-9323 I can run you through some options we have tested. We have these all in stock.
View: https://youtu.be/zkfPIsSdA-I?si=Ak57NXEIe0pZQU2a
I caught a couple of hotel valets doing a neighborhood joy-ride in mine and hitting the toot button every 50 yards. They didn’t realize I was on the restaurant terrace and could see (and hear) what they were doing. One was from Botswana, the other from Brazil. I didn’t grudge them the experience.I have the australian version of the pedal tuner. Its a fun toy, i like the valet mode that cuts acceleration response to half.
This is the right attitude to have in life.I caught a couple of hotel valets doing a neighborhood joy-ride in mine and hitting the toot button every 50 yards. They didn’t realize I was on the restaurant terrace and could see (and hear) what they were doing. One was from Botswana, the other from Brazil. I didn’t grudge them the experience.
I install the tuners regularly. Usually $100. I don't know anyone who has made a video of that. The connectors can be a challenge.Hey Dave, I just ordered both the ionic and pedal. Curious to know if you ever got to record a video of the IOBox on YouTube. I haven’t found any good ones.
Do you also install them? What would that run me?
