Activating the cargo bed light; how?
3:46 PM
PDX
In the rear of our QM beds (or tubs for those outside of North America), there is a light on the rear of the bed, opposite the tire, next to the tailgate. I'm not sure how to turn it on.
Since the QM does not have a traditionally located third tail light and bed light, typical on most pick-ups, light is at a premium in the bed. While I intend to add a switched work light to the roll bar at some point, I would like to make use of the included bed light.
I checked the owner's manual and didn't see anything.
How do I (we?) turn it on?
Page 45 of the manual. Turn on the ignition, then flip your overhead power switch to on. Then touch the white lens with your hand for more than 2 seconds. To turn off the light hold white lens for 1 second. Don't forget to turn off the over head power switch?
Thank you. I appears that my search terms through the owner's manual weren't correct.
The light should work for a short time once the vehicle is unlocked, or locked also, as the system is still active. I have been able to turn off the QM, lock it, and turn on the light in the bed without the overhead switch activated. (I have turned it off manually and not checked if it stays on for any length of time). If I come to it later, it will not turn on without activating the the lock / unlock button.
Good to know. I'll give it a test soon.
Latest posts
