I want to fix ARB air compressor inside the car, any good workshop in Dubai can do it for me?
Do you mind sharing some pictures? Did you experience any problems with the heat of the compressor? Also, where is the air outlet for you please?I did it at Ramy 4x4...single ARB pump under the rear seats and using the stock switches. Works well.
I also went to Ramy to install compressor under driver seat. No heat issue whatsover. Only downside is you can bump the switch while driving and start the compressor, not a big deal. This is the best place for the compressor cause you can control the compressor while monitoring the pressure on the car infotainment central screen.Do you mind sharing some pictures? Did you experience any problems with the heat of the compressor? Also, where is the air outlet for you please?
I have the twin ARB compressor installed under my front passenger seat and can confirm that it’s easy to knock the switch into the on position. I now have a small piece of rubber wedged into the top of the switch which stops it getting knocked on by mistake.I also went to Ramy to install compressor under driver seat. No heat issue whatsover. Only downside is you can bump the switch while driving and start the compressor, not a big deal. This is the best place for the compressor cause you can control the compressor while monitoring the pressure on the car infotainment central screen.
