Build Thread 8020 DIY
I built a van using 80/20 it was not the best idea because the hardware is ridiculously priced. In my last van build, I used uni-strut (painted with black bed liner)
Van build linky
80/20 Van Build
Nice work. It’s given me some ideas. I’ve never heard of these products. I’d been thinking of using ply with pocket hole joinery. But with this method I build an aluminium frame and use thinner ply for weight saving. Food for thought.
I prototyped my platform build using 2020 t-slot.
Each upright section was really strong and it was tempting to investigate this option... but ended up going with 20mm shs
Nice work. I’m not very good as a fabricator welder so I’ll try out the unistrut or t-slot stuff I think.
Yeah thin wall is a pain to weld, especially as it has been decades since I was on the tools... hence the thick raptor paint job ;)
Van build linky
80/20 Van Build
Fair enough - it’s just the “system” aspect of it and the one stop shop aspect that caught my attention. That is PURELY because of how lazy and incompetent I am - someone with more ingenuity and initiative could pull stuff together for less.
That was my thoughts, I am not a carpenter and I have no patience, so the 80/20 would be great. But, when it came time to close the fronts and make drawers, it was very difficult to tie into the rail without using the expensive hardware.
Also, since there is a hollow hole in the center (looking at a cross section on 80/20), one can't simply use a self-tap. It will drill tap the first side of the hole, then when it hits the intercenter of the second side, the screw will snap.
see here the center hole.
Also note how I simply cut aluminum angle and used 1/4" carriage bolts to build the structure.
There is a Light Ply available. Plenty of suppliers out there. I used it for a fold out bed top (y)
UltraLight Plywood - 40% lighter than your average plywood.
UltraLight Plywood
https://ultralightply.com
The perfect mix of hard and softwoods to maximize strength without weight. Lightweight. 40% lighter than regular Baltic Birch plywoods, saving tons on shipping ...
When I read your post, after reading the first bit I thought just use coach bolts. Reading farther that’s exactly what you did. 👌🏼. Save money on expensive fittings. You just call them carriage bolts.
Nice work. Some more pictures for inspiration please.
My whole storage system in the Grenadier was 1"x1" 80/20 (well, purchased from Tnutz.com which is the same product, substantially cheaper).... I also built out the entire interior of our Sprinter in 1.5"x1.5"; it's good stuff
Here my latest built (looks like a disaster here). I built it all out of Uni-strut. The beauty is that there was no shipping cost involved - it's all available at my local Home Depot.
The upper cabinets are bolted to unistrut rail- It's all built out of strut and 1/2 birch. The old van was 80/20 and thin plywood (I was obsessed with weight)
UniStrut Van Build below....
80/20 Van Below....
