windshield exterior fogging
5:16 AM
Inlet Beach, FL, USA
I'm having significant issues with fogging on the windshield EXTERIOR. I live in a high humidity area (FL). I have tried adjusting the ventilation so that no air is directed toward the windshield and have increased the interior temp a bit (although I don't want to go above 77 degrees for comfort reasons). I recently tried applying ClearVision which made the fogging worse. Most of the anti-fogging products I have seen are made for interior glass.
Anybody else have this issue and have found a way to reduce or eliminate exterior fogging?
Years ago I applied Rain-X to the exterior windshield my car. While large droplets of water would roll off in the airstream (as intended), the windshield would never fully clear in misty conditions. My takeaway is to be very selective about anything, included film, added to the outside of the “windscreeen”.
Mine fogs as well here in Dallas. Very annoying. It's due to the dash decoy vents blowing on that part of the windscreen. If you can block or deflect that air it will stop.
Yea it's an air leak to the windshield defroster vents when you use auto. If you use in manual, it won't blow on the windshield. They need to fix this with a simple software update.
What type of fogging? - just so we make sure that we are talking about the same things.
I found last summer, that the automatic setting would send a lot of cold air to the centre of the windscreen and I got a cold circle appear as it was blowing too much cold onto the screen in one place. In the winter, the auto barely sends any air to the screen and got full screen misting. I found using manual rather than automatic gave a better outcome for both summer and winter.
Thanks for the advice regarding the use of manual mode versus auto mode. I'll give it a try.
The dealers should give every new owner a leaflet that advises them not to use Auto or fan level 4 on the HVAC, it would save them a heap of time answering calls and emails.
Florida as are all areas in the Sub Tropics and Tropics are a funny beast. This problen is not unique to the Grenadier.
I use RainX on the outside of my windscreen and balance the interior temp to the dew point when possible.
I tightly rolled a couple of dark grey (to minimise reflection) microfibre cloths length-wise and stuffed one in each of the windscreen outlets. Simple solution which works well to virtually eliminate fogging...;)
FWIW: (It's also a known 'problem' with some Mercedes A class sedans.)
I’ve had fogging on the outside. In winter, I also get icing on the outside in the exact same spot. Believe me or not. The fix is on a level drive, cold engine in the morning, top up both coolant tanks (black and blue caps) to the max level. Coolant is probably running slightly low as trapped air has dissipated and needs coolant to balance out both high and low pressure coolant tanks. Similar to a gas central heating at home when balancing the radiators in the house.
I've not had this problem with my Grenadier YET…but did when I owned a Defender ‘23. I ended up purchasing a diffuser insert for the defroster vents that eliminated the problem.
If you just shatter your windshield, you won’t have a problem with fogging or icing - if it’s not shattered yet, give it a few weeks. No special procedure required.
Mine fogs up in the center of the windshield when I use the zone split function (air to footwell/main vents). Located in Houston.
Don't people just use their wipers if the exterior fogs?
Except it's just a small section right in the middle. The rest of the windshield is bone dry. Clearly you are not having this issue.
It develops as a pair of bufferfly wings right in the middle of the windshield down low.
Basically the same spot all the cracks are showing up - the air coming out of there on AC is REALLY cold and on defrost it’s REALLY hot. I think some owners have cooked up some kind of deflector solution.
