- Local time
- 12:17 AM
- Joined
- Sep 10, 2023
- Messages
- 417
- Reaction score
- 487
- Location
- Santa Barbara, California, USA
17 x 7.5 / 6 x 130 / 50mm offset Methods? And, what's the lug bolt thread spec?
Thank you sir!Yes they will (of course tire size will matter)
Lug nuts are M14x1.5
Wheel Centre Bore 84.1mm17 x 7.5 / 6 x 130 / 50mm offset Methods? And, what's the lug bolt thread spec?
You need nuts, not bolts.Looking at Lug BOLTS, they come in different thread lengths. Will the Sprinter specific ones work?
As stated by @Shopkeep , the Grenadier uses nuts not bolts (as it has studs)Looking at Lug BOLTS, they come in different thread lengths. Will the Sprinter specific ones work?
Damn, that's important to know! Any recommendations for a set to work with these Method wheels? Are y'all using stock lugnuts on aluminum wheels?As stated by @Shopkeep , the Grenadier uses nuts not bolts (as it has studs)
Who is fitting your tyres? I would wait until you get vehicle and are ready to fit the wheels and tyres, tyre shops will have the nuts and be able to supply the correct set in closed end black coated.Damn, that's important to know! Any recommendations for a set to work with these Method wheels? Are y'all using stock lugnuts on aluminum wheels?
single rear wheelI was looking at the lug nuts that Method Race Wheels offers on their site. They note that:
'Fits SRW only' with no explanation of what that means. Why do people do that? What does that mean? Thanks.
Yeah, that must be it! Thank you. (They couldn't simply spell it out.....grrr.)single rear wheel
You will need packs of 6 wheel nuts 14mm 1.5mm thread as the wheels are 6 x 130, 84.1 bore.I was looking at and wanted the Gorilla Nuts because they appeared to be top tier but all the offerings that I could find (admittedly, on Amazon) were 4 packs. Seeing how I need 5, I went with the McGards.
ETA: Anti-theft nuts
I ordered two 15 packs. Although I considered getting 10 three packs.You will need packs of 6 wheel nuts 14mm 1.5mm thread as the wheels are 6 x 130, 84.1 bore.
But if you ordered six packs of five nuts that will be 30 nuts, the same as if you had ordered five packs of six.
The hub bore has nothing to do with lug nut sizing; the question at hand would be whether the factory wheels are ball or cone seat, as the vast majority (all?) aftermarket wheels have a conical seatIf the wheels have a bore of 84.1 you can use the stock lug nuts.
