This pocket guide shows wiring point https://grenadier4x4.uk/category/electrical/Am I correct that there is a power supply point under the bonnet with a switch on the overhead panel? Is so, where do I find it?
Mmh - it's enough to start a conspiracy theory on... Mind you, this is the RH side and I've read the 25A connection is on that side. And I can't see anything suitable on the LH side.
Ah - good question. The pic is of my overhead panel. I did read somewhere that the 'pwr' switch simply keeps the USB port live for charging even when the ignition switch is off. But that should still leave me with one external connector somewhere...You said back in post #5 you have the basic station wagon. Just to confirm, you did add the optional HIGH LOAD AUXILIARY SWITCH PANEL & ELECTRICAL PREPARATION in your order? Sorry if I missed that somewhere. You did mention a winch switch in #16.
'Four additional, high ampage, pre-wired auxiliary switches with fuses and wiring running to various points in the vehicle. This option allows for quick and easy installation of aftermarket accessories such as winches and light bars and is activated using dedicated switches in the overhead console. This option includes four external electrical sockets in the tie-down rail recesses.'
That's the left sideThis is the outlet on the right side. Just behind the jumper post. Pair of wires taped to the harness.View attachment 7825368
So you only have the 10A outlet on the right hand side as you are looking into the engine bayView attachment 7825374
My jumper psot is on the RH side of the vehicle i.e. the LH as your stand looking into the engine bay.That's the left side
Perspective is everything Dave! RHS of the vehicle. LHS as you look under the bonnet.That's the left side
Good, good, but where is it? I simply can't find it.So you only have the 10A outlet on the right hand side as you are looking into the engine bay
Don't look for an outlet, look for two wires attached with some insulation to a big bundle of wires, left side of the vehicle unde the bonnet, but perhaps you know this.Good, good, but where is it? I simply can't find it.
Ah, yes, forgot there could be a difference between left hand and right hand drive.Here is where mine is on petrol version RHD circled in green View attachment 7825386
I think there must be another somewhere that I haven’t looked for yet as there should be both 10a and 25a supplies as you haveAh, yes, forgot there could be a difference between left hand and right hand drive.![]()
I'll have another look tomorrow to confirm, but no. See pic above. If we assume that side is for the 25A conne3ction, I have to really search hard on the other side...Here is where mine is on petrol version RHD circled in green View attachment 7825386
According to your picture above you don’t have the high load auxiliary wiring but you should still have the 10a supply under the bonnet but not the 25a supplyI'll have another look tomorrow to confirm, but no. See pic above. If we assume that side is for the 25A conne3ction, I have to really search hard on the other side...
According to your picture above you don’t have the high load auxiliary wiring but you should still have the 10a supply under the bonnet but not the 25a supply View attachment 7825388
The 10A should be there anyway. Ask your dealer, but sometimes they don't know eitherI give up. After spending even more time under the vehicle and leaning over both sides into the engine bay, I have followed the wiring loom and NO TAKE-OFF POINT. It's not there. Now all I can do is complain, and I'm afraid that apart from the good folk here, there will be nothing but deaf ears.
The dealer has already been asked. Here is their reply :-" "The 10A should be there anyway. Ask your dealer, but sometimes they don't know either
