what is the best compatible brake pads and disc to use for Grenadier
Brembo Front Pads for Grenadier:
Brembo Rear Pads:
Hi
It is possible to have the Brembos references on the boxes ?
Thank you for the instructions but honestly I didn't understand very well how to proceed....
I'll probably do the first pads change at the dealership with the mechanic.
I'm used to change land's fixed brake calipers and not these floating ones
Good plan. I wish I could work with an Ineos technician for a while.
In the very early days when Ineos were doing open days to look at the prototype Grenadiers in the U.K. there was talk of training workshops for owners, that’s gone very quiet now.
I am not sure but some digging yielded FMSI numbers for Grenadier's pads.
Front pads - 9168-D1944 (it can also be labelled D1944-9168). Looks like the fronts were used in Acura NSX (2016-2022), Mercedes MacLaren, and Maserati Grand Turismo. Brembo lists the first as P50078. Autozone lists the part but tells you it won't fit a 2024 INEOS Grenadier.
Rear pads - 9123-D1895 (also D1895-9123). A Google search for those brings up 2017-2020 Audi A6, Q7, Q8, and e-tron Quattro A8.
FindItParts.com has both front and rear pad kits in stock.
Now... the part numbers for the pads were found on RockAuto website. I don't know if they fit - ordered a set, will report the fitment results.
EBC makes some, I've used them many times on daily's to avoid so much brake dust like the Brembo's put out.
Have any part numbers? Brake dust drives me crazy.
Brembo does have ceramic pads, but they won't sell it to you in the U.S.
